i have some questions im trying to date a couple flatheads engines i just baught both of them have 8ba heads but as i counted one apears to have 23 bolts in the heads and the other one have i count 24 bolts in the head ??? whats the differnce here and 1 block number at the bell housing is E M2093 and the other one looks like 30E4 any body have have any clues for me to be able to date these two engines ???
All later Flatheads had 24 bolts. From 41 or so on, don't know exactly what year. The earlier flatheads had 21 bolts. Either you miscounted the one that you said had 23 or its not a Ford flathead. 49-53 flatheads had the drop in distributor, the earlier ones had the distributor mounted on the front cover. All 49-53's were essentially the same, except the Merc ones had 255 inches rather than 239. Can't help you on the numbers.
what are the head casting #s? Have you checked with the folks on FordBarn? Some of them know those flatties in & out and might be able to ***ist using those #s you provided. Ron
If the bellhousing unbolts, it's '49 to '53 ('48 in trucks). If the bellhousing is cast on to the block it's '48 or older. '40 and older had 21 bolt heads, '41 and newer had 24 bolt heads. Check out this website for more info. http://www.vanpeltsales.com/FH_web/flathead_model_IDchart.htm
