How could they ever quit making these?
Discussion in 'The Hokey Ass Message Board' started by R Frederick, Sep 15, 2010.
  1. R Frederick
    R Frederick
    from illinois
    Got some old CalCustom 9 fin valve covers in the mail yesterday. After an acid bath and some burnishing with fine steel wool and a br*** brush, *Instant Cl****. I love them!!!:D
  2. GassersGarage
    GassersGarage
    Are you gonna run a pcv valve?
  3. oldrelics
    oldrelics
    from Calgary
  4. ROBERT JAM
    ROBERT JAM
    oldrelics did your pcv fix work?
  5. GassersGarage
    GassersGarage
  6. R Frederick
    R Frederick
    from illinois
    I found a PCV and grommet that would fit into a starter wire conduit I had laying around. I drilled the back of the intake valley and mounted the standpipe in it by folding tabs over underneath with a chisel, siliconed in. Hopefully with the standpipe, I won't need a baffle.
  7. R Frederick
    R Frederick
    from illinois
    Thanks, I had to change the intake, rad hose, etc. just to get to use these. I love them, now I need to go through and see what else I can replace with vintage.
    your ugly white buddy.:D
  8. Zipper31
    Zipper31
  9. torker intake, HEI, billet water pump pulley for starters, if you were asking for help:D
  10. lowpunk
    lowpunk
    from berwyn, il
    Huge inprovement!!! Nice job and hope to be able to check it out that the Pileup this year!
  11. R Frederick
    R Frederick
    from illinois
    You're not supposed to notice the billet water pump pulley.:) I had a hard time finding a pulley to line up, that was the only option i had at the time. Maybe I need to round the edges up a little and satin finish it.:D You got me scheduling the modification of the water pump pully for this weekend now.
    And I'm a little too attached to HEI, it's too dependable.
  12. R Frederick
    R Frederick
    from illinois
    I hope to get in, this and my top are preparations for that very trip.:D
  13. djust
    djust
    from Oklahoma
    I drilled a hole in the rear of my intake and threaded it so I could hard pipe in a pcv valve to the back carb riser.
    Seems to be picking up to much oil because the pcv valve is now dripping some oil so I need to put a baffle in mine.
  14. R Frederick
    R Frederick
    from illinois
    Well, that's why mine's up in a pipe. I hope oil won't splash up into the pipe. I'll have to keep an eye on it, I'm not saying it won't either.
