Art & Inspiration how did he do that?
Discussion in 'The Hokey Ass Message Board' started by bangngears, Jan 1, 2026.
  1. bangngears
    bangngears
    from ofallon mo
    Things Henry did that my feeble little brain can not figure. No. 1 , how did he get the stainless on a 32 headlight bar? No2. Was the metal tack strip that holds the cloth on the roof stamped or bent ? Seems to me stamped would be logical because the holes in the corners are round. If the corners were bent the hole2 would be egg shaped. If stamped look at the amount of metal used, And Henry was a tightwad. Ok, carry on with your "how did he do that".
    lothiandon1940 likes this.
  2. CSPIDY
    CSPIDY
    PFM
    Jeff34 likes this.
  3. What I believe about the tack strips is that they were an Extrusion run through dies and a punch press much like the early Windshield frames. Ever wonder how those were made?
    Tim, dwollam and lothiandon1940 like this.
  4. bangngears
    bangngears
    from ofallon mo
  5. bangngears
    bangngears
    from ofallon mo
    They are mild steel. I use to make the tack strips from aluminum extrusion, but can not find any these days
  6. rockable
    rockable
  7. Tim
    Tim
    from KCMO
    Yeah probably similar do a big *** pull max with dies just running it threw. Next guy cuts and stamps the holes.
    The stainless probably goes on before the ends? I haven't cut a 32 up but the model A headlight bars I’ve messed with the ends are solid and the centers are hollow rolled tube.
  8. studebakerjoe
    studebakerjoe
    @bangngears might be able to find a Ford blueprint that may explain or at least hint at the method
  9. rockable
    rockable
    There are lots of threads on how to bend this stuff. Probably some here and Fordbarn. You have to make some tooling but it's not that hard. Probably make it out of mdf. Anneal the aluminum first.
  10. 29Sleeper
    29Sleeper
    from SoCal
    Or start with untempered -
    Aluminum T1 temper is formed by cooling hot-worked aluminum (like extrusion) and allowing it to naturally age at room temperature, giving it a stable, moderately strong state with good ductility and workability, ideal for parts needing minimal post-forming shaping, but it's less strong than T5/T6 tempers
    . Working with T1 involves traditional metalworking techniques like bending, cutting, and machining, but avoid excessive cold working, which can change its temper
  11. bangngears
    bangngears
    from ofallon mo
    Still havent figured how he got the stainless on the headlight bar.
  12. 1946caddy
    1946caddy
    from washington
    The ends were painted.
    The center stainless “wrapper” was crimped to the bar
  13. bangngears
    bangngears
    from ofallon mo
    I would like to see how it was crimped, being it has a curve.
