I have this 4 speed trans that I would like to install behind a 8ba Flathead. I have search for info but have not found much. I was told it is an easy install.
okay....not all knowing....but this is the set-up for my 1939 Ford cpe build - the Merc bellhousing was chosin because of the linkage works with the 39 pedals....we had to weld on two threaded dowells if you will to the top - the bottom matches up fine....not sure what anyone else is doing....the bell housing should be 49-50 Merc... should be able to do the same with a 49-53 Ford bell housing....
