how do I get the head off?
Discussion in 'The Hokey Ass Message Board' started by skatermann, Feb 15, 2012.
  1. You can also use your favorite liquid rust disolver, somewhat more effectively by filling the combustion chambers thru the cylinder bores after the pistons are removed and the block prepped like listed above. I am ***uming the pistons will come out from the bottom.
  2. Chris
    Chris
    Not all of em will...
  3. Dan Parker
    Dan Parker
    from Salem Al.
    Use a compression tester and put compressed air in the spark plug hole. It will lift the head a lttle. Maybe enough.
  4. bedfordboys
    bedfordboys
    from bedford va
    I feel your pain man. I went through this on my 35. I had to unscrew all the studs(they still wont come out of the head but they are unscrewed). The stud removers with the rollers(looks like a deep well socket) worked on some of them but a small pipe wrench got most of mine out and some of them broke. You cant worry about trying to save the studs. Its a *****
  5. Chris, if your not going to reuse the pistons, can you use a long drill bit and drill carefully through the top of the piston to fill the chamber with some rust solvent? I know its not the cure all here, but maybe some help with minimal work and expense.
  6. HankAz
    HankAz
  7. modelamotorhead
    modelamotorhead
    Had the same problem with a banger. I soaked the head in a creeping oil with the trade name of Kroil. It loosened the studs enough to wedge the head off and unscrew them the rest of the way with a pipe wrench. The stuff worked down the studs and around the head/block surface. I let it soak a week before attempting to remove the studs. You can get Kroil at their site online, or some machine shops may have it.
  8. thanks again you guys! I actually already have kroil, its amazing stuff!
