How do I get this thing off my Desoto
Discussion in 'The Hokey Ass Message Board' started by Barz51, Dec 28, 2005.
  1. Barz51
    Barz51
    I was trying but not succeeding in removing the Torque Converter/ fluid coupler from my Desoto 330. Does anybody now how this thing is attached? I figured it just slid on but I did not want to pry too hard incase there was a snap ring or something. Thanks for the help.
  2. Gotgas
    Gotgas
    from DFW USA
    Should be nuts or bolts that you can get to between the engine block and the flexplate.
    Air cooled trannys ROCK.
  3. squirrel
    there's one of them things laying in my yard, I think it has studs that go thru the crankshaft flange. Maybe take off the sheet metal cover that's bolted to the aluminum plate, just behind the oil pan, and take the nuts off from there?
  4. Bugman
    Bugman
    Yup, I'm betting the converter/ring gear is studded and you'll have to unbolt it from the crank flange. It's a real PITA. Good luck.
  5. Relic Stew
    Relic Stew
    from Wisconsin
    I think I remember my buddy bitching about taking one off his 392. A long flat wrench between the engine and flexplate to undo the nuts.
  6. bulletproof1
    bulletproof1
    from tulsa okla
    its bolted to the back of the crank,seems like you have to remove the trans to block adapter to get it off.
  7. chitbox dodge
    chitbox dodge
    from dunlap tn
    yep, your converter bolts straight to the crank. no you dont need to pull the adapter plate first. there is no flexplate on the powerflite converters. the converter itself is studded and youll need a long wrench to reach up in the gap in the adapter plate to get at the nuts to the "inside" of the crank flange. this would be the side closest to the motor.
    and if you think this is gonna be fun, wait til you pull the adapter hub (the thing holding you up from pulling the front timing cover) off the front of the crank. lots of PB Blaster, some heat from a torch and a very stout bearing puller "might" get that off for ya.
    rotsa ruck
  8. Mule Farmer
    Mule Farmer
    from Holland MI
    Aaaaa! took me a while to figure mine out also. It was a bitch in the front yard in the dirt and I busted my knuckles a bunch of times.
    where you from in Mich
    Bret
  9. Barz51
    Barz51
    Thanks for the help guys; I'll get at it in the morning. I just got a propane forced air heater so working in the garage in the winter is now a more viable option.
    Hey Farmer I'm from Gladwin. What's your location?
  10. oneyed
    oneyed
    Lots of lube and a dead chicken..
  11. Levis Classic
    Levis Classic
    Another Desoto Hemi man from Michigan? What are the chances - Mule Farmer is building a 330, I have a rebuilt 330 going in my 34 Coupe. Small world.
  12. Mule Farmer
    Mule Farmer
    from Holland MI
    Holland there are alot of guy from the east side of the state not too many in the middel or west side.
    bret
  13. socal_wrench
    socal_wrench
    my crank is out of the block and the converter is still on it.
    I haven't even looked at how to get it off.
    ( Cant afford the rebuild right now anyways)
  14. Barz51
    Barz51
    Eight bolts and two hours latter it's off. Thanks for the help guys.
  15. Mule Farmer
    Mule Farmer
    from Holland MI
    yep its a bitch but it will be worth it in the end.
    bret
  16. Barz51
    Barz51
    It would not have been so bad if the engine had been on my engine stand. BUT, it would not fit on the stand with the torque converter attached.
    Where do guys get your Desoto hemi parts? Hot Heads?
    Thanks again for the help.
  17. totally unrelated to torque converters,but...... I need a passenger side exhaust manifold for a 291 desoto hemi from 1955 or 56. any help? r.r.
  18. half empty
    half empty
    I just found this thread, yes! I'm at the point where I need to remove the torque converter/ fluid coupler from my Desoto 291 but wasn’t sure how to go about it.
    Thank you all and thank this site!
  19. sunbeam
    sunbeam
    It's pretty hard to beat the price of Falconglobal on Ebay for a stock rebuild.
  20. lanny haas
    lanny haas
    from Phoenix AZ
    Back in my mechanic days working on any Chrysler product was a total pain. Like they built the car around the part you need to take off....
