How do I hide the wires?
Discussion in 'The Hokey Ass Message Board' started by RMR&C, May 12, 2012.
  1. unkledaddy
    unkledaddy
    I had a similar problem with my column mounted tach.
    I got a piece of black electrical cord and removed the wires from the jacket. Then I fed the tach wires into the empty jacket and simply 'slack-wired' it from the tach through a hole drilled in the column drop. You will be surprised how much better those wires look when they're not encased in that convoluted plastic.
    As someone said earlier..........you can move the switch down the column a bit to minimize the wire run.
  2. sawbuck
    sawbuck
    from 06492 ct
    i used a shifter column tube... 40 ford i think...came with the upper and lower clamps... looks factory
  3. nick28
    nick28
    from Kentucky
    I just used the asphalt coated loom looped it under the column and down the column under the dash. Clean & simple.
    Not the best picture, but only one I have showing it:
    Sent from my iPhone using TJJ
  4. gimpyshotrods
    gimpyshotrods
    Two holes, two grommets, wires inside the column tube.
  5. unkledaddy
    unkledaddy
    It looks great, but nothing like the first picture you posted.
    How come you changed cars on us?
  6. chaos10meter
    chaos10meter
    from PA.
    I hid mine inside hot dogs, duct taped to the column.
  7. Squablow
    Squablow
    Late 50's Ford cars have a U-shaped steel piece that runs down the column to hide the turn signal wires, and it clips in place. Would look like it was factory, but I like the idea of a shifter tube as well. To me, taped up wires look like taped up wires, and trying to jam them down a column tube that wasn't designed to carry them is just asking for a short.
    I can take a pic of a Ford column with the pieces on it if you want to see it, just let me know.
  8. Slag Kustom
    Slag Kustom
    add 2 layers of black shrink tubing over the wires and it will never wear out or put a section of a plastic bottle inside column to hold the wires to the jacket
  9. hot rod pro
    hot rod pro
    from spring tx.
    my thoughts would be to just stick your hand out the window to signal, and leave the turn signal off the column. but if you still want to know what i would do, i like the idea of a painted line running the wires down the column.
    or even mounting the turn signal behind the dash with the lever pointing down under the dash.
    -danny
  10. RMR&C
    RMR&C
    from NW Montana
    I used a piece of steel tubing painted black.....worked just fine. Thanks for the input.
  11. Kramer
    Kramer
    Any sheet metal shop could bend up a low profile channel for the wires to go behind. Screw to the bottom of the column and paint the the color of the column. It only has to be tall enough to lay the wires side by side in the channel.
  12. Kramer
    Kramer
    Oops, I guess I was a little late on the post. Oh well, you got it done, that is the important thing.
  13. Shane Spencer
    Shane Spencer
    check out ian's $20 steering column tech. build a column and run the wires down inside the column. by far the cleanest imho and you can do it for cheappp, sell your column you have now and make money. the tech is worth a look
  14. Shane Spencer
    Shane Spencer
    lmao nvm. regard my dumb *** not reading the whole thread :rolleyes:. well anyways check out his tech, its still worth a look for the future
