my friend has a 69 firebird (yeah its not within the year limits) with a th350 and well it just doesnt shift worth ****. i mean it shifts at the right times and smoothly..but thats not really what he wants. is there any way to make an auto 350 shift harder? thanks guys.
either do what he said, or put a **** kit in it. unless it's worn out...then rebuild it and put a **** kit in it when you rebuild it.
get a small straight screwdriver and pull the Vacuum hose off at the vacuum Modulator at the right rear side of trans pan....----INSIDE-----the tube on modulator that the hose fits on- is an adjustment screw that will firm up the shift.
Get an overhaul manual,and aquaint yourself with the trans components.Remove the govener,there will be centrifical weights inside, remove a little weight off the weights, and it will shift at a higher rpm than stock. Remove the Accuumulator spring inside the acuumulator. That spring absorbs some of the pressure when it shifts.. remove the spring, and you will get tire chirping shifts,full pressure. You can also run a small gate-valve(plumming supply) beetween the vacuum modulator valve,and manifold vacuum tubeing. Less vacuum= harder shifts. They used to sell such a thing like that called"dial a shift". B+M's 'trick shift' fluid is good for firmer shifts also. Sparky
I could be wrong but I believe the vacuum mod controls when it shifts not how hard it shifts. Get a 50 dollar shift kit into it. Also, the trans will shift harder with a stock converter than with a high stall converter, the high stall slips more.
Screw it in Later/Firmer Screw it out Earlier/Softer. Take the spring out of the ac***ulator and replace with a piece of broomstick about 1/4"shorter than the spring and it'll get a real big 1/2 shift but won't help 3rd much. T.OUT
if you want to get real fancy, and leave the ****** working nice at part throttle but have nice firm shifts at full throttle, then open up the clutch feed holes a bit, and plug the ac***ulator p***ages with freeze plugs with a small hole in them, also shim the pressure regulator with a TH400 horseshoe shim. I can give you more specifics if you want. A **** kit is a shift kit with a missing letter.
thanks a bunch guys, ill relay this info to him and we'll do some tinkering this weekend to see what we can come up with.
I had a very hard shift kit in my roadster,,,,,It got old Quick but I kept driving it until the sprag gear broke in half,,,, I had to replace it and took the kit out,,,now my neck doesn't snap ever time the gears change,,,,,,,, If you use a shift kit,,,,go with a mild one,,HRP
Shift kits ****...don't get one. Build it if you wanna get it to shift hard... and if you leave the ac***ulator spring out... your gonna wanna get a good quality sprag gear cause you'll break that *****..if you drive like me anyways..
yeah, restricting the ac***ulator is much better than disabling it, you get comfy shifts until you put your foot down then it will shift hard...
been looking for this screw in the modulator tube thingy and cant find it ,please explain exactly where it is and what screwdriver i need in real easy to learn steps for the less abled please....................Marq
The factory modulators are not adjustable, but the aftermarket replacement (small) ones are. Pull the vacuum hose off the modulator. In the hole in the ****** that you pulled the hose off, is a screw with a hole thru the middle of it. Use a 1/8" flat blade screwdriver, and turn the screw.
so ive been checkin out shift kits and that looks like the way to go, i had no idea theyre so affordable. so for the transgo kits, which stage would be the best? 1&2 or a 3rd? im guessing 3rd is pretty rough, so maybe 2nd for a street application? thanks for all the replies.
The dude that rebuilt my TH350 told me to run Type-F fluid instead of the Mercron-Dexron stuff. He put a mild shift kit in it for me, and I have prolly around 70K miles on this ******. It gives a nice kick in the **** when it shifts under medium acceleration... not that slushy stock GM stuff. Under hard acceleration (doesn't need to be WOT), it'll bark 3rd gear @ about 80-83 mph. (I have a SBC 350 in my 52 Chevy sedan with a one-legger 2.73:1 rear.) All this, but it's really pretty tame in "regular" driving, so it's definitely not obnoxious like some are. As for the Type-F, I have heard that you should never mix it w/ the M-D fluid, but don't know for sure. I put this into a freshly-rebuilt empty ******.
Yup, shift kits want the type F fluid. Don't mix it. Put in a new filter and screen while you're in there.
