How do I prevent post shutdown flooding?
Discussion in 'The Hokey Ass Message Board' started by luketrash, Jul 18, 2006.
  1. 972toolmaker
    972toolmaker
    from Garland Tx
    No pics but i found al. plates that you sandwich with std. gaskets that fit 2 bbl or 4bbl holly bolt pattern about 3 of them makes a great heat sink. the isolator also works NAPA carries them.
  2. ray
    ray
    from colorado
    way to bring up a 2 year old post with advise that largely doesn't apply to the primitive one barrel holley carbs that we were talking about.
    there is no edelbrock carb to replace a one bbl holley.
    5-6 psi is often too much for these carbs. and an aftermarket pump that puts out that much volume is not necessary here either.
    i agree with the phenolic spacer, but you ain't gonna find one at summit for a one bbl carb! you gotta MAKE one.
    the carbs have a gl*** fuel BOWL. that's why we are running them. we put up with the tuning problems cause they look cool.
    get a BIG RACING FILTER! haha.
    may your second attempt at posting on the internet be more successful.:D
  3. layin_frame_56
    layin_frame_56
    from Ohio
    I am having the same problem with my 29 roadster also...But when I drive it and it gets heated up and i shut it off it wont start for days. It just clicks with a full charge on the battery..Any Ideas????
  4. GoFastorDieTrying
    GoFastorDieTrying
  5. southcross2631
    southcross2631
    Build a spacer from 1/2 inch marine plywood. It cured my 57 Y-block Fairlane from doing the same thing.
