How do i remove a Vin tag?
Discussion in 'The Hokey Ass Message Board' started by fnjunk, Jul 4, 2008.
  1. fnjunk
    fnjunk
    from Australia
    Can anyone tell me how to remove a vin tag from a 50's Buick as i am about to blast the body and don't want to destroy the tag?
  2. Mad~Max
    Mad~Max
    If it is spot welded, then cut out the whole panel it is spot welded to, and weld it back in when you're done. If it is 4 rivets, just drill them out.
  3. fnjunk
    fnjunk
    from Australia
    Yea it is spoted i think ???there are two holes behind it where it has been spoted is there no other way as the body is excellent don't relly want to cut it.Thanks
  4. RoadrunnerRod
    RoadrunnerRod
    At work (I'm a sandblaster), we usually just cover up vin tags and stuff like that with a few layers of duct tape. Just make sure it's stuck down pretty good on there! :)
  5. low budget
    low budget
    from Central Ky
    :eek:
  6. chopped
    chopped
    leave it on and cover it, you don't want some cop to think you faked it.
  7. 325w
    325w
    If ya get real technical about it, It's a felony to remove it period. However on the tri 5's you can run a good knife blade under it working as you go and the y will pop right off. Then use the famous JB Quick weld to put it back.
  8. panic
    panic
    Don't remove it unless there is absolutely no way around it.
    And if you do, certainly don't tell anyone.
  9. The Law
    The Law
    from N. AZ
    Thats a felony in Texas? Here in the "free" state of Kalifornia it all depends on your intent. I'd just drill out the rivets and pop them back on when the time comes.
  10. gulfwarsubvet
    gulfwarsubvet
    This works very well.
    Electrical tape (few layers) also works well.
    I've done it a bunch of times, with small parts, in the blast cabinet.
    I've blasted the hell out of mirrors, and other delicate parts, with no damge after masking them this way.
  11. fnjunk
    fnjunk
    from Australia
    Thanks think i will mask them up and blast around them.
  12. Goztrider
    Goztrider
    from Tulsa, OK
    You might even make sure the blaster knows that you don't want that area blasted into oblivion. Let them/him know about the VIN tag and what you've done to protect it, and ask that they take a bit of diligent care around it.
  13. old4dlvr
    old4dlvr
    Slightly O/T but does anyone know who makes new vin tags/ This would save a lot of problems.
  14. rc.grimes
    rc.grimes
    from Edmond, OK
    Don't disturb it if at all possible. If it has to be removed save an invoice from the sandblasting to cover your ***.
    In response to an earlier post vin tampering is a FEDERAL FELONY in all 50 states. With that being said........don't tell anyone.
  15. Ol Blue
    Ol Blue
    from In
    I've used a rubberized tape used by people that sandblast designs/letters in cemetary headstones. The sand just bounces off. That said, that thick double-sided tape might work just as well.
    Ol Blue
