how do I remove a windscreen without breaking it
Discussion in 'The Hokey Ass Message Board' started by tylerae40, Oct 3, 2007.
  1. I'm stripping a 70's car for parts and need to take out the windscreen but its stuck in with that stickerflex stuff, how do i get it out without breaking it?
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    be vewwy vewwy carefull. Theres a tool made just for that purpose. Check with your local tool suppler or maybe get a local gl*** guy to come by and take it out for you. You can also use a small strong wire like guitar string and find a place to poke it through and get a buddy on one side and you on the other, tie both ends to a wooden dowel and work together to saw through the stuff.
  3. ^yup, works for windsheilds too ;-)
  4. Volvo544special65
    Volvo544special65
    I have done like lobucrod says a few times, usually a wire from a mig/mag welder works... And as already stated, be careful!
  5. old beet
    old beet
    That works, take your time, don't force anything, don't let the wire touch the gl***. Denatured alcohol may help soften the seal..........OLDBEET
  6. wvenfield
    wvenfield
    The wire will work but IMO if you have never done it, I'd pay a windshield guy a few bucks to do it.
  7. enjenjo
    enjenjo
    from swanton oh
    The easiest way to do it, is to measure the center of the gl***, and make a mark there with a Sharpie. Then rap it smartly there with a three lb. hammer. Since it is now broken, you don't have to pull it. I hate cutting out windshields.
  8. Volvo544special65
    Volvo544special65
    Or a heat gun.
  9. CB_Chief
    CB_Chief
    from Oklahoma
    HF sells the tool to cut the seal for less than $10. Then it only requires one person...
  10. old dirt tracker
    old dirt tracker
    from phoenix
    the tool is hard to use with out experience. 2 guys and a wire will work the best .i use one strand from a emergency brake cable.
