How do I remove adhesive? 1935 Nebraska plates
Discussion in 'The Hokey Ass Message Board' started by oldfart, Mar 18, 2008.
  1. I have a set of NOS 1935 Nebraska license plates that were stored in the original envelope w/a piece of plastic between them.Over the years,the plastic degraded and now the plates have plastic melted to them.I tried to remove some of it(on the back) with Greased lightening.It took the paint but no plastic.Dish soap did nothing.Any ideas?Will someone please post pix for me modelt26@bellsouth.net
  2. thirty7slammed
    thirty7slammed
    from earth
    Might not work on your plates, but WD-40 removes adhesive.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I wish i could help you..I have a simular problem facing me this summer.
    the PO of my Tudor Glued the top vynl on the roof with liquid nails:mad::eek:
  4. Fairlane Dave
    Fairlane Dave
    Maybe soak 'em in hot water with mild dish detergent.
  5. lostn51
    lostn51
    from Tennessee
    if your going to repaint them (since it took the paint on one try) id soak them in lacquer thinner, that stuff will take anything off!!
  6. Dan10
    Dan10
    from Joplin
    How about a 175 degree oven for a little while to get them unstuck.
  7. Stickanddice
    Stickanddice
    from Boston, MA
    Goo Gone. Don't know how it affects the surface of the plate so maybe try a small drop in the corner, but it's worked great on some other painted surfaces I've used it on.
  8. Pontiacres Ranch
    Pontiacres Ranch
    Prep sol or 3m adheasive remover is pretty mild, I sometimes use it after taking off vinyl graphics
  9. ANewBeat
    ANewBeat
    from Floriduh
    There are some non-toxic adhesive removers based on citric acid, available at any major hardware store, that should do the trick without harming the paint.
  10. 5window
    5window
    I've removed stuck on masking tape by soaking it in oliver oil. Don't know if that will help,but it won't harm your plates. Good luck. If you find something that works-post it during tech week.More folks will read it,
  11. Bob 1743
    Bob 1743
    I would go with the WD40 idea. I have removed bumper stickers with it. will not damage paint.
  12. zman
    zman
    from Garner, NC
    I've always had good luck with the 3m stuff...
  13. Gooo gone is the shit. I belive its made from natural orange souls. So might be pretty gentile in theory.
