how do i set up a rear area mounted radiator
Discussion in 'The Hokey Ass Message Board' started by tatooedtrash, Jan 8, 2008.
  1. tatooedtrash
    tatooedtrash
    hey guys i seem to have a lil space issue in my engine compartment and i see this being done alot so what i have is an S10 blazer chassis that i cut 5 inches off the front of my frame to clear my front clip im putting a 39 plymouth pick up on it by the way i would like to put the radiator behind the cab between the frame rails how do i do the plumbing pass the motor,trans,drive line and exhaust thank you for your input
    Wanted 39-46 ford,chevy,dodge,plymouth rear pick up truck fenders thank you
  2. tatooedtrash
    tatooedtrash
    hey dont all help out at once
  3. Jalopy Joker
    Jalopy Joker
    Did you measure before you started this project? No simple task to do what you are planning to do. Sending hot water a long ways to a radiator only causes more heating problems, and much more. Direct air ducts and dual fans and an angled well supported big radiator are a start.
  4. tatooedtrash
    tatooedtrash
    well i have a 77 gmc as my donor for motor,trans, radiator,steering colm,
  5. touchdowntodd
    touchdowntodd
    i seriously doubt that radiator will do the trick.... i would suggest a big fat 4 core aluminum one (as untrad as that may be)
  6. tatooedtrash
    tatooedtrash
    ok had to grab some dinner so the longer the plumbing the longer it takes to cool off is that what i got so far i mean i see a lot of rat rods with the same set up im talking about hell even the core off road trucks are running this sort of set up i just need some pointers in the right direction on this also will i have to change the filler neck to a 90 degree
  7. bradberry00
    bradberry00
    I want to do something similar to this in a future project as well....I want to put the radiator in the trunk so I have an empty grille shell up front with a nailhead peeking out....so I would be quite interested in hearing what people say.
  8. brewsir
    brewsir
    I would use exhaust tubing to run the coolant to the radiator...and short pieces of rad hose to attach it all together. Then you will need to run an electric fan for airflow. Now...between the framerails will cause a problem because you are sucking hot air from under your ride....you also won't have much room for a large radiator with the driveshaft in the middle.
  9. bradberry00
    bradberry00
  10. JohnnyP.
    JohnnyP.
    email bear metal kustoms. one of our new employees has a rear mounted radiator in his 26 T. see if he can send you some pics.
  11. bradberry00
    bradberry00
    if you get pics, can you please post them?
