How do these motor mounts look?
Discussion in 'The Hokey Ass Message Board' started by evintho, Dec 13, 2013.
  1. evintho
    evintho
    This is my first try at building motor mounts and am looking for advice. Will this work? 2" square tube welded directly to the inner rail. I feel like I need some sort of gussets but really nowhere to put them. The car is set at ride height and the motor is in position. I was thinking something coming off of the top and side of the rail but that would look completely funky!
  2. choptop40
    choptop40
    hey hey . they look ok . lets see em welded , maybe a gusset or two would work as well....
  3. aonemarine
    aonemarine
    from Delaware
    You can do better than that...break out the card board and start making templates...
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Hope the square plate is just mockup. Past that, that will be fine. A good weld around the tube and a gusset wont be needed. The tubing is its own gussets.
  5. Dave 39
    Dave 39
    They will be fine. I know you're going to do something to tidy up that piece of 1/4'' plate' but other than that your good. Dave
  6. Mr48chev
    Yep, that square plate needs some t******* to look good.
    That setup should function better than just running the tube straight out from the frame rail like we see all the time.
  7. swade41
    swade41
    from Buffalo,NY
    Those will be fine, I did something similar on my t-bucket and lots of abuse later no problems. The only difference is that have part of my tubing on the top of the frame rail as well as on the sides.
  8. aonemarine
    aonemarine
    from Delaware
    Ok Ive had a few beers now so im letting it out....That form follows functiion ****, yea they function... but you can take the measurements from them and sculpt out something that doesnt look like a stick welded to the frame. I guess it depends on what you want. if looks arent that important then go for it. But the little things and time well spent make winners...
  9. cbillelder
    cbillelder
    The only thing I might suggest if your frame rails are tall enough is to turn the mount tubing 90 degrees so the wide dimension is vertical instead of horizontal. All your weight
    and forces are in the vertical direction so you would want the widest section going up and down.
    Good luck.
    Ooops, sorry, I see now that your are using square tubing. Your first picture kind of threw me off. I thought you were using rectangular tubing. Never mind.
  10. evintho
    evintho
    Well, sounds like they'll work! Thanks for all the input! I'll either trim the plate round and flush with the rubber biscuit or trim it 1/4" wider than the biscuit. Nothing fancy. It's a basic hot rod.
  11. My thoughts exactly! Drill some 2" holes in the tube tho
  12. 1971BB427
    1971BB427
    from Oregon
    I think they'll work fine. I probably would have used rectangle tube instead of square, so the tube could be notched at 90 degrees and have part of it sitting on top of the frame for extra strength, but I tend to get carried away with mounts.
    I'd also think some "lightening holes" would make it look neat, but a nice clean, smooth mount isn't ugly.
  13. evintho
    evintho
  14. need louvers ?
    need louvers ?
  15. prewarcars4me
    prewarcars4me
    from Bhc, AZ
