Art & Inspiration How do you clean engine turned panels on a dash
Discussion in 'The Hokey Ass Message Board' started by Dman, Jun 19, 2024.
  1. Dman
    Dman
    I have a car with engine turned panels on the dash. The dash has rusted above the panels and the rust has washed down over the panels. What is a good way to clean these without doing harm to them? Thanks
  2. Unkl Ian
    Unkl Ian
    The engine turning was done on steel ? Might have to use some sort of acid.
    Phosphoric Acid changes Iron Oxide into Iron Phosphate. I think you want
    to use something else. Have you tried CLR ?
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Polishing compound used for paint finishing. It's very light abrasive so should not cut into the machine finish.
    Another option is tooth paste. This is also good for polishing and cleaning delicate materials.
    seb fontana likes this.
  4. continentaljohn
    continentaljohn
    Yeah I would start with something fine like toothpaste Crest has more abrasives the aqua fresh and work your way to heavier compounds and then .0000 steel wool. Most engine turning is very light and not deep into the surface .
  5. '29 Gizmo
    '29 Gizmo
    from UK
    Holy cow, that's next level detail.
    I have got to remember that one.
    seb fontana and rattlecanrods like this.
  6. continentaljohn
    continentaljohn
    We use toothpaste when polishing plastic . So if we machine it or even bend it with heat the toothpaste will polish her right up..
    rattlecanrods likes this.
  7. Bandit Billy
    Bandit Billy
    If all the above fail, re-turn it.
    05snopro440 likes this.
  8. gimpyshotrods
    gimpyshotrods
    Liquid Wrench and a rag.
    RDR likes this.
  9. deathrowdave
    deathrowdave
    from NKy
    I cleaned mine very well when I turned it and cleared the work . It looks as good as the day I did it many years and mikes ago.
  10. RodStRace
    RodStRace
    Always go from least slowly up to most aggressive. I'd also suggest trying each on the BACK of the part before applying to the face. If the staining has gone down the front, it's probably on the back, too.
  11. ALLDONE
    ALLDONE
    don't ever try that on a 58 chevy dash...
  12. Deuce Lover
    Deuce Lover
    0000 steel wool ?
