How do you clean sandblasted metal?
Discussion in 'The Hokey Ass Message Board' started by D.SCOTT, Jan 19, 2010.
  1. D.SCOTT
    D.SCOTT
    Hello. Wonderin the best way to clean sandblasted metal before welding. any info would be greatly appreciated! Thanks!
  2. mj40's
    mj40's
    If it is freshly sandblasted and done well I don't think it would need cleaning. I have had no problems welding it. It’s the contaminates with in the metal that causes welding problems.
  3. buckeye_01
    buckeye_01
    ^ What he said. ^
  4. jreeder41
    jreeder41
    At most run some 80 grit sandpaper over it if needed
  5. Kail
    Kail
    from Austin, TX
    if its freshly blasted, thats as good as it gets. if its rusty, then take a roloc and clean it up till you get good metal (but dont take off to much and thin the metal out)
  6. alchemy
    alchemy
    We have had problems TIGing on freshly sandblasted steel before. We just ran a wire brush on the electric grinder over it real quick. Just enough to get the small sand particles out of the pores of the metal. Not doing any rust cleaning, just brushing off the sand residue.
    Really made a difference for us amateurs!
  7. DeucePhaeton
    DeucePhaeton
    Make sure you don't have contaminents in the sand blaster.:eek:
  8. D.SCOTT
    D.SCOTT
    Thanks for all the responses! Alchemy hit it on the head. Because there always seems to be a little bit of sand/media left in the small pores, at least enough to contaminate a weld. thanks again.
  9. nofin
    nofin
    from australia
    go over it with plain compressed air to blow away the grit. Do this outside!!!
  10. Probesport
    Probesport
    and don't use brakeleen no matter what.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yep..winner
  12. 85-percent
    85-percent
    As a side note - have you guys noticed that body filler doesn't stick very well to sandblasted metal? You would think it would almost weld together, but noooooo......
    jim
  13. russnunn
    russnunn
    from Florida
    hit with a grinder 60 or 80 grit should be fine
  14. art.resi
    art.resi
    Alcohol on a rag and wipe it down after you wipe it with a plain rag first. If you are not
    concerned about rust I wash with soapy water and rinse well with fresh and dry with a
    towel and then the alcohol rinse as a dryer. If you go fast it won't rust.
  15. HemiRambler
    HemiRambler
    One of the ch***is guys I know told me that I should NOT TIG weld my 4130 ch***is with blasted joints - instead I should wire brush them. He mentioned (as stated above) about the contamination from the sand embedded into the metal. This guy is VERY sharp and IIRC he did some testing for a job of his - so I gave great weight to his advice. Is it overkill?? I dunno, but it didn't take hardly any effort so I figured it was cheap insurance.
