How do you clean white walls?????
Discussion in 'The Hokey Ass Message Board' started by impalamike, Jun 9, 2006.
  1. impalamike
    impalamike
    from Texas
    I just bought a new car Monday (see pic) and the bias ply whitewalls are yellow. Any idea how to whiten them up? Thanks, Mike
  2. 49 Fastback
    49 Fastback
    from Ohio
    I've heard Bleche-White works well.
    Tucker
  3. Auto proud tyre cleaner....
  4. 3034
    3034
    Try AJAX cleanser on a rag or brush.
  5. RadirWheelsGuy
    RadirWheelsGuy
    Never use Bleach white!, If you do dont get a drop on your wheels, it eats them up bad.
    We use Lemon Fantastik with a brush (lemon works the best i dont know why.) on the Radir Dragster slick whitewalls here on the cars at the shop.
  6. flynstone
    flynstone
    i use a sos pad..............works good
  7. MonsterMaker
    MonsterMaker
    Same here...always brought em back to bright white for me.:eek:
  8. leadsled01
    leadsled01
    FYI, after you get clean, I use a good coat of Future Floor Wax to keep them looking good for months.
  9. unclescooby
    unclescooby
    from indy
    We use Lemon Fantastik with a brush (lemon works the best i dont know why.) on the Radir Dragster slick whitewalls here on the cars at the shop.[/QUOTE]
    Good to know. I was just about to write you and ask what you recommend. I've got your 15x8.20 slicks on my truck and LOVE them. What kind of mileage should I be getting out of these things? I've heard some really low numbers and I've got about 1000 miles on them, and other than being dirty, they look great.
  10. bigken
    bigken
    Get your girlfriend to do it. All the ones I've found were good on their knees, and they know how to use all those 'cleanin'-chemicals, anyway. :D
  11. Stromberg97
    Stromberg97
    from Lowell, IN
    Yes...bleach-white will mark up painted wheels. I've used SOS pads...or 0000 steel wool with soap in the past.
  12. 50Fraud
    50Fraud
    I've found Bleche-White works very well for cleaning off yellow and curb scuffs, but it definitely causes the whitewalls to craze and check over time. I might use it for a one-time cleanup on a newly acquired car, but I'd switch over to SOS or cleanser on a scrub brush for the long haul.
  13. Coker says to never use Bleach-white 'cause it'll crack the whitewalls. Of course, they recommend their Coker WWW cleaner. Anyone used it?
    Bryan
  14. 400 grit wet or dry works great(wet with some Simple Green water,,& always rinsing).
    320 if they're really bad.
  15. 40StudeDude
    40StudeDude
    Is that a true Impala?
    I don't recall seeing a two-door with chrome around the side windows like that...and the chrome spear on the side looks like Bel-Air trim...the whole car just doesn't look right to me for some reason...explain please.
    Thanx,
    R-
  16. 23 bucket-t
    23 bucket-t
    brillo pad is better :)
  17. Tony
    Tony
    Bleach white will crack the white wall. It also discolors them as well turning them a yellowish color, at least it did on both sets of whites i used it on..
    When i bought my diamont backs, they recommend sos pads, and if you want a cleaner use a water/simple green mix, or a non bleach cleaner like the fantastic that was mentioned earlier.
    I've cleaned the whites on my 53 using billo pads, or SOS, and not only do they clean up great, but there's also no cracking, and they stay cleaner longer with NO yellowing at all.
    And thats after a year and a couple thousand miles..
  18. chiefbobber
    chiefbobber
    from NH
    One time about twenty years back I was visting a friend and when I went outside to leave his old man was going over the wide white on the back of my Harley bobber with a rag and brake fluid. I had never before cleaned it and I couldn't believe how freakin white he made it. I'm sure you wouldn't want to get it on your paint and I'm not sure what it might do to the rubber.
  19. Bad Bob
    Bad Bob
    from O.C. Baby
    The best thing i've found is one of those yellow sponges with the green scrubber on one side,and dish-washing soap.Works like a charm!
  20. 28chevrat
    28chevrat
    Scotch brite pad and ajax...my were super yellow in the sun for a long as time tryed alot lot of **** and thats the one that works the best......
  21. Punchy
    Punchy
    from Orange, CA
    Westleys Bleech-White is awesome, just don't get it on the wheels......Comet and a scrub brush would be my second.....
  22. Chad s
    Chad s
    I use it, it works great. Its a bit expensive, but I just used up my bottle after a year. Ive used bleach white in the past, the Coker stuff definately works a little better, in addition to their claims of it not hurting the rubber like bleach white may.
  23. Cool, thanks...the shop threw some in when I bought my WWWs, but I haven't used it yet. It's probably just liquid Ajax!
    Bryan
  24. noboD
    noboD
    Lestoil, smells like a biohazard, cleans excellant. Doesn't like little cuts on your hands, burns like hell.
  25. Chad s
    Chad s
    Its smell doesnt resemble any cleaning agent I have ever come across, so I doubt it. Im definately going to try some Ajax though, as I dont have any more of the Coker stuff, and by the time you order it through mail, its like $15 for that damn bottle.
  26. TimW
    TimW
    from Kentucky
    I use scotchbrite pad and ajax...works great.
  27. louvers
    louvers
    from alameda,ca
    Back in the 50's we always used SOS pads. It really works
    fine. Many of the cars went to auto shows and the white wall tires looked great.
    _________________________
    Life just gets better every day, with a little help from your friends.
  28. seymour
    seymour
    from PNW
    I can't tell what kind of tires you have, but certain brands yellow really easily... I always use Simple Green and if they're the ones that like to yellow with a few days, lacquer thinner is your friend.
  29. SanDiegoJoe
    SanDiegoJoe
    I use this stuff called Bar Keepers Friend and a red scotchbrite pad. My wife buys it to do the dishes.
  30. VintageIgnition
    VintageIgnition
    Alliance Vendor
    from ma
    I have had good luck with Fantastic as well.
