How do you "coil" fuel lines?
Discussion in 'The Hokey Ass Message Board' started by ckdesigns, Mar 15, 2006.
  1. ckdesigns
    ckdesigns
    from Ogden,Utah
    Not sure what the process is actually called but I am wondering how to bend fuel and oil lines into the nice loops. I have a tubing bender but it only bends to 180 degrees.
    Thanks for the help.
  2. dodgerodder
    dodgerodder
    Hello ck. I'm sure others will reply with a better way, but heres how I have coiled lines before with my imperial bender that has always worked for me, and its also a 180 degree bender.
    I hope this is easy to understand, its one of those things thats hard to explain, but simple as can be to see it done.
    1. I Just start out making my first 180 bend wherever I want the coil to start. Now I have a "u" shape.
    2. To make the spiral, grab the leg of tubing that will be the "coiled" part, and bend it up(by hand) at a slight angle.
    3. Now do another 180 bend. This will give you your first "loop". Repeat these steps til you have the desired amount of loops that you want.
    Hope thats not too much of a mess to understand. The tighter of a radius that your bender does, the smaller the size that each loop will be. You could practice with a s**** brake line or something to get the feel for it. Hope this helps a little
    Dan
  3. seymour
    seymour
    from PNW
    I just wrap it around a steering column or whatever is layin around.
  4. mikekillstheday
    mikekillstheday
    If you fill it with sand it will not kink. then wrap around anything. just make sure to blow out the line real good afterwards.
  5. ckdesigns
    ckdesigns
    from Ogden,Utah
    Thanks for the help I'll be trying it soon.
  6. Fresh469
    Fresh469
    from Benton, KY
    if you fill it with sand to keep it from kinking, make sure it's packed good and keep it topped off with sand because as you bend it, the inside of the tube will get slightly larger and could result in a kink....
  7. Tha Driver
    Tha Driver
    from S.E. USA
    I always use any round tubing or pvc or whatever. If you're careful you don't need to fill it with sand, unless you're making a VERY tight circle.
    ~ Paul
    aka "Tha Driver"
    I don't take ****; I don't give a ****. I'm not in the **** business.
  8. Kurt
    Kurt
    I use a old hood spring. Wrap it around anf then unthread it off. The coils keep it spaced nice and even.
  9. Dirty2
    Dirty2
    I like that !!!! I will shure try it next time.
  10. 48fordnut
    48fordnut
    I used to make trans coolers out of alum tubing. wrapped them around broom handles ,till i found out about the hood springs, that worked good.
  11. blindman
    blindman
    from NH
    When I bend fuel or brake lines, I take the tubing, hold it tight in one hand, and use the handle of my floor jack. I keep wrapping till I get the coil size I want...also allows for a little "give" in the line!!
  12. 5window
    5window
    At plumbing supply houses, they sell these 10" long springs/tubing the right diameter to just fit over your tubing and bend it without kinking. Cheap and they work well because the tubing is supported equally though-out the bend.
    Not to hi-jack the thread, but I bought a roll of fuel line tubing. How to I flatten it out to get it into a straight run?
  13. Brad54
    Brad54
    from Atl Ga
    I've done it several times--I always run up to the local tire store and ask if I can bend the line on the post of their balancer machine. The balancers have nice big ACME threads with round channels in them. I always hold it against the post with one hand, and then smooth it down the threads with the other. Has always kept them from kinking on me.
    The hood spring idea does sound like it would work too.
    -Brad
  14. Bruce Lancaster
    Bruce Lancaster
    "I bought a roll of fuel line tubing. How to I flatten it out to get it into a straight run?"
    Just send it to the CKdesigns guy, and ask him to send you his straight piece. Done!
    Actually, rolling it on a flat surface (after uncoiling to some semblance of straight) while pressing down on it with a flat board will do a lot.
  15. mr5by5
    mr5by5
    A 1 quart gl*** soda bottle makes a nice size coil - you can also find lots of cans around about the right diameter to make a nice cool-can with a coil this diameter... Of course it is now 2006 and finding gl*** bottles is not as easy as it used to be! They are all metric dimensions now too - what is equivalent to a quart in liters (sigh). Life was a lot simpler in the 60s!
  16. flatheadpete
    flatheadpete
    from Burton, MI
    Mmmmmm...beer.
  17. 5window
    5window
    When I was out in Iowa last month they had 5 Liter(yes!) can of beer in the supermarket. That would have been a nice size coil.
  18. primer
    primer
    from clio mich
    i always use a beer bottle, but you have to empty it first and if you kink the line just empty another bottle and try again :D
  19. jakdupkustoms
    jakdupkustoms
    I have a bunch of spare v belt pulleys of all different sizes layin around works great for bending tubing just wrap it around the pulley then unscrew and repeat as necesarry.
  20. I know it looks cool, but does coiling the lines have any actual mechanical significance? ie does it improve soemthig or reduce the effect of somehting?
    Cheers,
    Paul
    PS. Love the hood spring idea :)
  21. ckdesigns
    ckdesigns
    from Ogden,Utah
    Thanks for all the replies. Now another question or two.
    Why do people bend loops into lines?
    Is it fashion or function?
  22. seymour
    seymour
    from PNW
    ****'ll work harden and break.
  23. chitbox dodge
    chitbox dodge
    from dunlap tn
    it allows for expansion and contraction of the line from having to be run from a stationary member to a slightly moving one. this sets up vibrations which in case of a straight tubing piece would rupture. it doesnt mean you should swap your heater hoses to coiled tube, but anything that only moves slightly can probably done effectively. you dont need a whole lot of coils to do this either, maybe just one or two. however coils are really cool looking.
  24. tommy
    tommy
    In the refrigeration industry the old timers would always put a loop or two right near the flare connection uaually at the compressor. It allows the compressor to move on it's rubber mounts. In the event that the flare cracks, you can cut off the damaged flare, staighten the last loop and reflare the tube without having to patch it together.
  25. mr5by5
    mr5by5
    I think all the guys with the comments about expansion/contraction and/or relative motion/vibration concerns are on the money as far as the "typical"reason for coiling hard-lines.
    I have done it for two other semi-practical applications:
    -"Cool Can" fabrication where you make a coil of line to place inside a can of ice for keeping fuel cool during racing.
    -I tried it to provide alternative to the exhaust manifold "heat stove" to warm the auto-choke mech. on my '55 Chevy in-line six. The sheet metal for the old "heat stove" would not work with my Offy dual-carb intake so I made a coil of tubing and located it close to the exh. manifold in hopes that would heat the chokes enough to pull them off. It doesn't work but it looks cool!
  26. Tha Driver
    Tha Driver
    from S.E. USA
    In addition to the above, it also allows the brake lines to remain intact in the event of an accident (allowing you to stop the car after impact). It's also a good way use up excessive lenght of a pre-made line.
    ~ Paul
    aka "Tha Driver"
    Giggle Cream - it makes dessert *funny*!
  27. flatheadpete
    flatheadpete
    from Burton, MI
    Glad I was able to find this one. I was about to throw my bender out in the road. I'm gonna hunt up a hood spring tomorrow at work.......any better procedures for bigger (3/8") copper line that works better?
  28. Bugman
    Bugman
    I use my vice for straightening lines. I'll get it as straight as I can, then lightly clamp it between the vice jaws 5" at a time to get it nice and straight. It works well for smaller straights, but long front to backs are still somewhat wavy. I'll try the board thing next time I have to bend some up.
  29. SPEEDBARRONS
    SPEEDBARRONS
    loops are called "mechanics loops" extra length for servicing
  30. Metric coils in an old hotrod just looks wrong! :D
