How do you deal with your sufface rust?
Discussion in 'The Hokey Ass Message Board' started by GatorO'dell, Feb 26, 2008.
  1. spudshaft
    spudshaft
    I had parts of my truck blasted by 2 different people. One guy kind of chewed up and warped stuff, the other made it look like it just was stamped. Not sure wat the difference is, but if you get somebody worth a poop, blasting works well. I also used the wire wheels on smaller areas, but for an entire vehicle, that ****s.
  2. Autojunkie
    Autojunkie
    3M Metal Prep, thinner, and 3M scuff pads.
    Mix 50% with water in coffee can and put some thinner in another coffee can. Dowse one scrub pad in the metal prep can and scrub away. After cleaning a decent-sized area, do the same with another scrub pad dowsed in thinner and clean over the area where you just applied the prep.
    Make sure to wear thick rubber gloves and don't wear any clothes you don't want ruined. It's a strong acid, but it really does the trick. You can buy it at most auto paint supply stores.
  3. No, you don't listen.............soda does NOTHING to rust.
  4. JDHolmes
    JDHolmes
    from Spring TX
    Surface rust I grind off with 80 grit (actually not grinding, use the variable speed buffer/sander) if in large areas or hand sand with small areas. Sometimes, a wire wheel. You've gotten a lot of in-depth answers when you only asked about surface rust.
    After, I hit it with a good degreaser. Then treat with either Picklex or Rust Blast. I prefer picklex because then it doesn't have to be hit with water again (i.e. water and bare metal = new rust). Picklex can be left untreated for a long time inside and can be painted over directly. (Same with Rust blast or other converter, but rust blast gets washed with water after application).
    finally, before paint (or primer) I hit it with a scuffing pad.
  5. lotus
    lotus
    from Taft, CA
    what are you talking abou? just look at this rust.
    There even is a spot that has a hole the size of a quarter! ;)
    seriously though...I sand and use osphos to treat the metal then lightly sand and primer.
  6. TooMany2count
    TooMany2count
    from Cahokia,IL
    Phosphoric Acid.....joe
  7. HomemadeHardtop57
    HomemadeHardtop57
    Really??
  8. 34toddster
    34toddster
    from Missouri
    This is rust?!
  9. hotcargo
    hotcargo
    Yes , Really
    actually I have a long skinny crate lined with plastic to do just ch***is rails
    cheers Steve in Oz
  10. hotcargo
    hotcargo
    Oh , I forgot .........light surface rust........you guys got Dioxedene over your way , I have been using this stuff for a lot of years on small jobs , which reminds me , I gotta get some more..............Steve in Oz
  11. for light surface rust on new metal i spray with inox rub with green scotch pad and dry wipe off with a rag.
    Al.
  12. Speedmaven
    Speedmaven
    Hand sand or wire wheel on Milwaukee angle grinder...also, Ospho...good stuff. Yep, I do it the hard way too. This time I was lucky enough to find a `57 from Texas, so I have much less rust than my last couple...
  13. oilslinger53
    oilslinger53
    from covina CA
    i put red wheels under it
  14. DanCollins
    DanCollins
    I also use the purple stripping wheels on the makita power tool, you just want to use the edge of the wheel, not the face. The ones I used to get were from sunchaser, but I think 3M might have bought them out or something? anyways, they work....
