how do you determine bolt pattern?
Discussion in 'The Hokey Ass Message Board' started by 29AROD, Aug 14, 2006.
  1. 29AROD
    29AROD
    this is probly a stupid question. how do you measure the bolt pattern on a wheel? I am looking to install 1940 ford brakes on my 29 A and am looking for some rims and would like to be able to check to see they will fit. thanks.
    29arod
  2. Bluto
    Bluto
    You buy on-a-those plastic thinggies at the swapmeet It's got all the bolt circles drilled it it.... But there's red ones and green ones and I can't ever remember which is metric and inch
    Hope that helps :)
  3. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Those plastic things are the best damn junkyard tool, ever. It sure beats squatting in poison ivy while trying to measure and avoid bugs/snakes...
  4. TINGLER
    TINGLER
    Measure from the outside edge of one hole to the middle of the hole directly across from it.
    edit: and yes those plastic things rule.
  5. houtex63
    houtex63
    from houston
  6. 29AROD
    29AROD
    thank you
    so i just went anc checked my A and it measures 5.5 for the bolt pattern ( stock) is this correct?
  7. Yup!!
  8. 29AROD
    29AROD
    thanks
    i just bought the little plastic thingy online.
  9. squirrel
    if I'm looking for 5.5" bolt pattern wheels, I just look for this distinctive shape, notice the square indents around the stud holes.
    one of these days I'll buy a dozen of those plastic thingies, one for each car and several to lose around the shop
  10. NITROFC
    NITROFC
  11. guiseart
    guiseart
    I thought it was from middle of one to middle of opposite one... edge to middle????
  12. Depends on number of lugs.
    http://www.mrt-wheels.com/boltpattern.html
  13. squirrel
    with a 5 lug pattern, the diameter of the circle is a bit larger than the center to center distance between two opposite studs, because the studs are not all the way opposite each other. You have to add about a quarter inch to the measurement, and a quarter inch is about half the diameter of a stud...so it just happens to work out right if you measure from the center of one stud, to the outer edge of an opposite stud.
  14. usmile4
    usmile4
  15. squirrel
    I could just go out to the wheel pile with a sharpie and a piece of cardboard
  16. guiseart
    guiseart
    That's why I love this place!
    4-bolt is center/center or edge/edge then right?
  17. squirrel
    if there is an even number of bolts, 4, 6, 8, 10, etc you go center to center.
    If it's an odd number of bolts, use the center to outer trick...but on a real big bolt circle like a wide-5 ford or early VW, it wont' work right.
  18. 4 2 GO
    4 2 GO
  19. 29AROD
    29AROD
    now i know why all the old timers told me to join this site.
    1. becouse the wealth of knowledge is so great.
    2. and so i would stop bugging them every other day or so.
