Technical How do you find an exhaust leak.....
Discussion in 'The Hokey Ass Message Board' started by rockable, Apr 20, 2014.
  1. rockable
    rockable
    I'm going to pull the heads this weekend. I gave up on trying to get the bolts out with the heads in place.
  2. stimpy
    stimpy
    a little trick we used on big trucks , while hot first center punch the bolt head to shock and break any corrosion welding in the threads then while the manifold is hot take a chunk of crystaline beeswax ( the canning wax bar or a long burn candle is made from it ) and apply it to the bolt heads and let it melt in ( you might have to keep warming up the car or hit the head with a torch) , do that to the bolt heads to get lube under them , then take the wrench and tighten them a smidge ( just a little turn 1/16 or 32 is all it takes ) , it stretches the threads of the bolts so the grip is loosened , and then loosen it ( do this while its warm and right after tightening it , as when it cold the bolt shrinks and tightens its grip ) , you have to pitch the bolts afterwords as they will not hold torque again as there threads are stretched , but you should anyways as the old bolt is probably bottlenecked from rust .
  3. rockable
    rockable
    Can't get the torch to the head of the bolts without burning stuff. That 455 is wide. I have lots of room fore and aft. Not much side to side. That's why I'm just going to pull the top end.
