How do you french headlights from scratch?
Discussion in 'The Hokey Ass Message Board' started by essexrat, Nov 20, 2009.
  1. essexrat
    essexrat
    I'm sure it's in here somewhere, but was just wondering if anyone has a way to french headlights from scratch???I mean without having to buy a kit to do it...Thanx
  2. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Weld the headlight ring to the fender and make the head light bucket mount from the backside, up in the wheel well.
  3. Rickybop
    Rickybop
    The "kits" don't french them...they tunnel them. The term to "french" means to "make flush". The traditional method is to weld the headlight bezel in place, and then modify bucket to be mounted from inside the fender. It makes for a bit of a PITA to mount and adjust, but not so terrible. Removing the tire makes it easier. - Rick
  4. johnny bondo
    johnny bondo
    from illinois
    what they said. take off the chrome first, and this is ***uming you have steel trim rings.... the plymouth and dodges have pot metal so you gotta use chevys ect. you could braze/solder pot metal ones on i think though. as far as the buckets go you just grind the lip off and screw it in from behind as stated. those kits looks stupid.
  5. Yaril
    Yaril
  6. twofosho
    twofosho
    Probably why the term "frenched AND tunneled" was used a lot in the "little book" days, tunneling required a LOT more work.
    A number of different "rings" (bolt on fender extensions like 52 to 54 Ford, 55 Olds, etc.) out there that are popular for this or you can make up your own from round rod and fill the gap to the fender with bits of formed sheet metal. Essentially what you are doing is eliminating the body seam between the fender and the fender extension (headlight bucket or ring).
    If you don't want the grief of going up into the inside of the fender to adjust the headlight, a lot of cars used a bolt on inner ring to span the gap from the fender extension to the actual headlight, exposing the adjusting screws when removed ('75 Cordoba comes to mind, just like the ones I have saved for just such a project).
  7. rodknocker
    rodknocker
    In the latest Rod&Custom magazine, there is an article about using 49 chevy truck healight buckets and making them adjustable with some pretty simple mods.This was just to conquer the adjustability issue.
