How do you get the rear seat back out of a 1950 Ford?
Discussion in 'The Hokey Ass Message Board' started by daren, Mar 7, 2004.
  1. daren
    daren
    I have a shop manual but it doesn't state anywhere the procedure. On some of my other cars you just take out the 2 bottom bolts and lift it up. The 2 bottom bolts are already gone, but I can't lift it up for shit. Am I missing some other bolts or should I just eat some more Wheaties? I'm going back out to work, will check back later.
  2. 50Fraud
    50Fraud
    You may have to lift hard enough to crush the mouse nests inside the springs.
    Are there another pair of bolts reached from inside the trunk?
  3. fuel pump
    fuel pump
    from Caro,MI
    Probably too many heavyweights do the wild thang in that seat over the last 50 years. Are there a lot of stains on it too [​IMG] [​IMG]
  4. nor cal nic
    nor cal nic
    try removing the seat bottom then pulling up and out on the back. that worked on mine...
    nic
  5. Machinos
    Machinos
    My car's not a Ford, but the seat back is bolted in like 6 places onto the bracing that goes across the back under the package shelf.
  6. gotcha
    gotcha
    from Sanger, TX
    I just pulled the back seat out of my 49 today...When you get the bottom out, there are 2 screws near the floor that hold the back in...They take a 3/8 socket, then you just lift up on the back and it's done...
    JP
  7. nor cal nic
    nor cal nic
    [ QUOTE ]
    JP
    [/ QUOTE ]
    i guess my screws were gone... i've been told i have a few screws loose.[​IMG]
    nic
  8. plmczy
    plmczy
    Go get a very big pry bar and...... [​IMG]. later plmczy
  9. daren
    daren
    You know fuel pump, I thought the same thing and you are probably right. When you sit on my back seat you basically sit on the floor, after the snap crackle and pop of the broke springs. Unfortunately I haven't been able to get some ass in that back seat yet, but my hopes are up!
    Ass for the mouse shit yeah there was plenty under the bottom after I scooted it forward. No money though, damn
  10. fuel pump
    fuel pump
    from Caro,MI
    daren,
    If these old cars could talk I can only imagine the stories they could tell. A year or so ago there was post about the stuff that guys found when they took their cars apart. Some of them were unbelievable.
  11. JSM56
    JSM56
    ummm, when all else fails, cutting torch?
