How do you guys remove OLD masking tape?
Discussion in 'The Hokey Ass Message Board' started by Carnuba, Jul 18, 2012.
  1. Carnuba
    Carnuba
    What are the tricks? Thanks
  2. brian55lvr
    brian55lvr
    from ma
    goo gone---prep sol---3812----laq thinner
  3. theHIGHLANDER
    theHIGHLANDER
    Gently scratch the top of the tape with a red scotchbrite. Watch your stainless, just try to hit the tape and open it up a bit. Soak it in good ol fashioned mineral spirits. Keep it wet, maybe do it a few times. It'll come right off and not hurt anything else. W/out getting it too hot, a little warmth before the mineral spirits helps sometimes.
  4. plym_46
    plym_46
    from central NY
    wd 40 or pb blaster works without danger of scratching.
  5. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    Best I've used is 3M adhesive remover. Coomes in either a quart or an areosol.
  6. Sumfuncomet
    Sumfuncomet
    Ditto what hispeedlowdrag said.......you will not damage paint, good for taking off bumper stickers, decals, tar spots etc...good stuff.
  7. 60galaxieJJ
    60galaxieJJ
    Zippo lighter fluid
  8. pitman
    pitman
    ...x2
  9. mikhett
    mikhett
    from jackson nj
    dont use wd 40.i like wax% grease remover.If you ever repaint wd40 will cause fisheyes, and it seems to get everywhere.
  10. Fenders
    Fenders
    I use Ronsonol, but it's all Naphtha.
    Also good for removing price stickers from books etc.
    Let it soak, gently peel away with a blade......
  11. hotrod0317
    hotrod0317
    This is what I used in the navy to remove adhesive residue from aircraft canopys that cost over 200,000 dollars. It is called alphatic naptha and you can usually pick it up in gallons in some hardware stores cheaper that zippo lighter fluid.
  12. 8flat
    8flat
    This.
    And next time use a good quality autobody tape, it can be in place for 2years and still come off easy.
  13. slammed
    slammed
    Take what brand of remover you buy and soak a paper towel with it. lay on the offending surface and let IT do the work. Come back later and wipe easily away.
  14. Cyberdyne
    Cyberdyne
    from Olathe, KS
    I usually knock the broad out with a 2X4 before pulling the tape... keeps the screaming down and doesn't draw attention. ;)
  15. outlaw256
    outlaw256
    funny this comes up now. i just spent 3 days s****ing tape off the trim of a car i put on 2 yrs ago. that **** sat in the sun for atleast a yr.i used everything i could think of and NOTHING worked. so i ended up keeping a rag of thinner runnin up and down the trim followed by a razorblade.dumb*** me scratched it up some. ive never done anything so stupid!!!!!!!!!!!! well i have but im not telling you.
  16. RidgeRunner
    RidgeRunner
    from Western MA
    Bug and tar remover has bailed me out when nothing else was handy.
    Ed
  17. Blue One
    Blue One
    from Alberta
    Buy an keep handy a can of Goo be Gone and you will love it. I do, just don't care for the smell of it but it works.
