how do you keep people from jackin your ride?
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Sep 24, 2008.
  1. junkjunky
    junkjunky
    No self respecting theif would take any of my stuff
  2. studebaker46
    studebaker46
    you know i may be just lucky but ihave never had one of my hotrods messed with not my studebake 46 p/u or my dodge p/u. been to the frog follies in evansville with studebaker and never even took the keys out theifs want something they csan seell now just my ho tom
  3. Nick Flores
    Nick Flores
    I've used this trick for years. The probabilty of them even bothering to lift the hood is right next to zero if not less.
  4. adam401
    adam401
    I make sure my cars are always broken or apart so that even I can't start them.
  5. shock733
    shock733
    from Florida
    THIS WORKS GREAT
    I owned a 33 3 window that came with this setup. a remote alarm box with a gravity switch [ if they try to tow ] and a pressure switch under driver seat [ if they to sit on it ]. the setup worked great and didn't make a sound when turning it on/off. nobody know it was there. it didn't lock the doors or blink the lights. in NY they get em quick, never had a problem but was glad it was there. it had a very loud and unique squeal. put a 12 pack on the seat one day with out turning it off and my ears rang for hours. but over insuring doesn't hurt either.
  6. ZZ-IRON
    ZZ-IRON
    from Minnesota
    50 Olds secu***y system
    he's trained to go for the nuts
  7. Abomb
    Abomb
    So, you guys that swap wires around, or pull the coil wire and replace it with hose do this everytime you park your car ???? I doubt it. That would **** everytime you go to the store for a soda.......Plus, if I were a thief, and I wanted your car, I'd know that you are doing something under your hood to disable your car. I'm guessing here, but I'll bet people that are going to steal something more specialized than a camry or honda accord probably scope out there target a little bit.
    I pull the keys and lock the doors, and I pay my insurance.
  8. 65fordguy
    65fordguy
    yeah, why I would want something as a simple as a switch or combination of switches.. but of course that does add to the list of things that could leave you sitting on the side of the road... I have thought about a removable "racing" style or the likes ... steering wheel. pull the pin and walk away... course then Im stuck carrying a steering wheel.
  9. Nick Flores
    Nick Flores
    My rig isn't a daily driver and the whole neighborhood is used to seeing me under the hood. Mine's a 64 F100 and is just a bit too long to live in the garage, so on the driveway she be. We live across the street from the police station in a pretty good neighborhood where loud parties and stop sign running is a big deal, not too much in the way of GTA. Moving around a couple wires is a good way to prevent some random ***** that happens by looking to ****** an easy ride home. Locks won't always stop 'em and i'd rather not deal with the head-ache of an insurance claim.
    :DOh yeah, Lots of guns and mean scary dogs help too...;)
  10. Travis
    Travis
    Uh, don't you go to prison if you shoot some theiving ***** outside of your home regardless of property lines and the fact that they're stealing?
  11. ugly fat chick in the backseat always works!
  12. Stevie Nash
    Stevie Nash
    Simple... conceiled cut off switch. :cool:
  13. AllSteel36
    AllSteel36
    A thief will get it if they want it bad enough, just insure it and enjoy the ride.
  14. AnimalAin
    AnimalAin
    My ignition box has an anti-theft feature. Saved my coupe one time; rat *******s got as far as in front of my next-door-neighbor's house when it stopped and wouldn't start again. Found the car sitting there in the morning.
    That ignition system seemed a little spendy when I bought it, but not so much after that.
  15. oldchevy
    oldchevy
    keeping it simple works best for me. theives don't like to work.
  16. Edsel_Presley
    Edsel_Presley
    I pull the engine every time I stop...even at stop lights.
    :cool:
  17. historynw
    historynw
    Power wire to my distributor, it came loose one time even I couldn't take my car until it dawned on me. I fixed it nice and neat then added a switch for the times when the car isn't homein the garage.
  18. oilslinger53
    oilslinger53
    from covina CA
    Some thieves use a short wire with an alligator clip on each end, and a screwdriver to steal old cars because you don't have to break anything, or cut any wires to do it. Wont stop them.
  19. MarkzRodz
    MarkzRodz
    Got a call from the UAMS police one night, said my '96 Caprice was idling in the parking lot. I drove up there and the Drvrs window was smashed and the column was broken all to hell. The police drove up and the guys ran off.
    All they had to do was push the brake pedal down to engage the shifter into gear and they'd been off. They were in a panic or something and were trying to get it into gear when the police showed up. I left my wife my truck and drove the Caprice home and replaced the broken stuff with Roadmaster peices.It's part of life and just go on.
  20. 29nash
    29nash
    from colorado
    Dual straight pipes. It'll wake me up, and the neighbors.
    Total up the rest of my bag of tricks, the deterrent factor is so high that I leave the key in it all the time. Standard transmission with elongated hole in the shifter slot between low and reverse. If you hunt around for the gear, when you put it into reverse, then try to shift to low(without knowing the drill) it locks up in reverse and you can't get it out without crawling underneath with the pliers. Coupled with the fact it has to be choked to start it, even in the summer, with manual choke that if you don't baby it, it'll flood. Even if they get it started, odds are after backing out it'll lock in reverse.
  21. flatheadpete
    flatheadpete
    from Burton, MI
    I have 200 lbs. Of canine that protect me and mine. Come on over for a visit anytime.....better hope I or my neighbors are around.
  22. flatheadpete
    flatheadpete
    from Burton, MI
    Any of that good 'ol B body for sale?
  23. AllSteel36
    AllSteel36
    All the "start-defeat" tricks aside, whatcha do when they come to your place with a roll back? A thief that want's you car and plans ahead, will be able to defeat almost any alarm/etc, you design.
    Insure it and enjoy it.
  24. patrick66
    patrick66
    Lots of threads on "how not to get your car/truck/trailer/tools/shop/home ****ed with" on here.
    If I ever catch anyone doing anything to my **** and I get my hands on them, they'll have difficulty processing solid foods, have a distinct inability to walk (ever again) and be singing three octaves higher than they could before. ***uming they'll even be able to breathe.
  25. AllSteel36
    AllSteel36
    No kidding, only the local "wanna-be's" are looking to steal my stuff;)
    If I had something that warranted a ride on a roll back, it'd be tucked deep away...then again, I watch that show "ovehaulin", and they swipe some good projects on thier truck.
  26. AllSteel36
    AllSteel36
    That line reminds me of a movie I saw...
    "Why did you shoot him 6 times?"
    "That's all the bullets mine gun held"
  27. arca39
    arca39
    from summit il
    don't matter if it is nice or pos. my 85 burban with homemade roof ladder rack and rust was taken, 80 chevy are common-just a srewdriver and they are in---door lock poped out,then they crack the col. and pop the start rod. and they are gone... kill switch is best imo. and daddyfink-- is that middle rifle a true model 44?
  28. PhoenixFear
    PhoenixFear
    Lots of good ideas in here as far as security, I'm quite paranoid although I wouldn't intend on driving a nice car and leaving it for an extended period of time unless in my garage or something. I'll probably put a killswitch in a****st other things, I have heard it is good to have multiple security devices combined in a vehicle.
  29. junk
    junk
    Trunk Monkey as posted earlier, although I don't want a trunk full of monkey **** and banana peals.
    I'm of the mindset to make it hard for a thief, but if they want it it's gone. They make car insurance for a reason.
    How would you easily defend from a rollback? I've heard from the repo world that dawn soap under the tires makes any vehicle in park with the brake set slide onto the rollback pretty good.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  30. Special Ed
    Special Ed
    It's never been a concern of mine. I take my key out of the ignition on occasion, but that's about it. I guess I've been lucky so far, and live and visit areas where people respect my ****....
