How do you remove a headlight switch from a 1956 cadillac
Discussion in 'The Hokey Ass Message Board' started by cookiemonster131, Apr 13, 2011.
  1. cookiemonster131
    cookiemonster131
    So the question is how do you remove the headlight switch from a 1956 cadillac. i know it has a bezel but the bezel will not let the switch come out of the dash without the knob and post removed. does it have a release switch on the switch itself like a ford?
    Thanks ahead of time for the help!
  2. recks
    recks
    from oceanside
    If It i like my '60 you have pull the switch all the way out and then press the spring loaded ****on located on the side of the switch near the back side. my dash is off so it's easier to see but that should do the trick. hope it works.
  3. cookiemonster131
    cookiemonster131
    sounds good, kind of figured that was the way but it is hard to even get my hand up the the switch in the dash much less hunt for a ****on, anyone else have experience or want to confirm what recks said?
  4. 2x..I did it on a 57....pull the knob/shaft out and push the spring load ****on on the switch by snaking your hand and arm up under the dashboard. OH, and you have to do both at the same time as the ****on will stick and you have to wiggle the shaft slightly to remove it from the switch.
  5. cookiemonster131
    cookiemonster131
    Thanks guys you are the best!
  6. Sir Woosh
    Sir Woosh
    Hope that worked for you as most GM switches were built that way. My 55 Olds switch comes out the same way. Won't need to push the ****on putting it back in. It will snap lock back in when you push it the in the hole.
  7. Bad Luck Engineering
    Yep, I had to pull the headlight switch out of my '56 Cad last week. It's not too tough once you find the ****on, as long as it isn't totally frozen in place. I already had my instrument panel out, so I guess that's probably considered cheating.
    Good luck.
