How do you remove Gylptal?
Discussion in 'The Hokey Ass Message Board' started by Dave Zapatka, May 20, 2013.
  1. Dave Zapatka
    Dave Zapatka
    I have a motor that was painted on the outside with Glyptal. Wasn't my decision. Does anyone know how to remove it or can I scuff it up and paint it?
  2. Dave Zapatka
    Dave Zapatka
    Motor is all assembled and ready to roll. Misscomunication with the engine builder 20 years ago!
  3. sdsmith33
    sdsmith33
    from kansas
    Dave Lacquer thinner on a rag should take it off or brake kleen. If it is that old you can probably scuff and paint. I have had some bleed through problems on freshly gylptaled items. Hope that helps a little
    D Smith
  4. Dave Zapatka
    Dave Zapatka
    Thanks for the suggestion I will give it a try. Still open for suggestions.
  5. texasred
    texasred
    from Houston
  6. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Ive become a fan of easy off oven cleaner. nasty shit and takes off grease like no other.
  7. Nother word ? Gylptal what the heck? Is this.
  8. paco
    paco
    from Atlanta
    Kewl GE paint that is super tough & was used to fill porosity inside engines so oil gets back to the pan where it is suppose to be.
    I retired from GE (Power Gen.) and we used it on some of the inside of oil bath bearing housings ... very slippery stuff when cured.
  9. Ramblur
    Ramblur
    I just epoxy primed mine and painted it.
    It was a never run 55 Hudson "crate" motor that looked like this when I started.
    After freshening the bores and new valves it came out of the wash cabinet at the local machine shop looking like this:
    I figured if that didn't touch it I was good. Epoxy primed and bc/cc and now it looks like this.
  10. SimonSez
    SimonSez
    This is from the Glyptal web site and they list it as a primer, so sounds like
    you should be able to scuff and paint over it.
    1201 GLYPTAL® Fied Enamel does more jobs—and does them better—than any other red enamel available on the market today.
    1201 makes no compromise withquality. it is designed to give outstanding performance andsatisfaction . . . always.
    That's the secret of 1201's success.And that's why the average user has been specifying it and buying it for over 30 years.
    The outstanding all-purpose paint. Although 1201 was orginally developed as an insulating paint for electrical applications such as the treatment of coils and armatures, its outstanding resistance to corrosion, moisture, oil,acid, heat, dust and salt spray has made it popular throughout industry as a Primer. Sealer, Adhesive and Protective Finish.
    There are literally hundreds of uses for 1201. Some of the more typical industry uses include:
    Primer for structural iron and steel
    General plant maintenance Sealer for concrete floors
    Primer and finish tor motor. generator, and transformer housings
    Anti-moisture coating on thermostat, water cooler, and truck control parts
    Sealer lor pipe and stud threads and vacuum systems
    Anti-corrosion protection for winches and other out- door apparatus
    Electrical insulation for coils and armatures Adhesive for gaskets
    Coating tor interior of hydraulic tanks, and bearing cases
  11. Rusty O'Toole
    Rusty O'Toole
    I would just paint over it.
  12. Larry T
    Larry T
    It runs off when sprayed with Berryman B-12.
  13. RDAH
    RDAH
    from NL, WI
    Berryman B-12 is sold at our local Wal-Mart & it cut threw pretty much
    any painted surface. I Use it a lot. Don't get it in a cut on your skin.
  14. fbcoach68
    fbcoach68
    from SOCAL
    Smoke and mirrors!
  15. williebill
    williebill
    That Hudson motor is beautiful.
  16. Dane
    Dane
    from Soquel, CA
    Me 2
