How do you remove side glass from door
Discussion in 'The Hokey Ass Message Board' started by Boones, May 18, 2004.
  1. Boones
    Boones
    from Kent, Wa
    Trying to replace my rear door side gl*** and since the surround it fixed and I can not lean the gl*** to get it out I need some help. I do not want to break it.. Do I just force it out of the felt channel and force it out
  2. If it wont come thru hole in lower door-you may have to remove the channel run[flathead phillips or glue in?] around the top of gl*** to allow it to lean inwards enough to come up and out.you've took the four little screws out that hold it to bottom strap at regulator -right? [​IMG]
  3. Boones
    Boones
    from Kent, Wa
    thanks , after writing this I went back outside and decided I had to open the channel since it was glued in. It came out with a tug but I got the new gl*** in and its back together. Now the front door is apart (wingwindow ***y out also) and tomorrow I will put new front gl*** in...
