How do you remove the pinion pilot bearing retainer ring?
Discussion in 'The Hokey Ass Message Board' started by bbdeuce, Jan 22, 2010.
  1. bbdeuce
    bbdeuce
    from GA
    Any help is appreciated. How do you remove the pinion pilot bearing retainer ring on a ford 9 inch to replace the pinion pilot bearing? I have searched but not much info out there, I have read to "pry" it out but what do you use? I have tried multiple tools and ways to pry it out with no luck. Thanks, Jim
  2. AllSteel36
    AllSteel36
    It should come right out, you prying the correct way? That cast retainer is "lipped".
