How do you separate a connecting rod?
Discussion in 'The Hokey Ass Message Board' started by a/fxcomet, Feb 4, 2004.
  1. a/fxcomet
    a/fxcomet
    from Eugene, OR
    I am trying to get my brand new Eagle forged steel I-beam rods apart. Is there a secret to this? When I have taken apart rods on a motor, I just tapped them with a rubber mallet. But what do I do when they are tight, and not in the motor? Can I hold them in a vise and tap with a mallet? I just dont want to mess anything up.
  2. Fastsporty
    Fastsporty
    find a piece of closet dowel rod pop in the vise and slide the rod over the end, and Blamo with the ruber malet. you should be able to do it that way.
    FS
  3. dadseh
    dadseh
    About 9500 RPM should do it! [​IMG] [​IMG] [​IMG]
    Sorry, couldnt resist it.
  4. fordiac
    fordiac
    from Medina, Oh
    droppin a valve will do it too. it will also give you some more clearance with the cylinder wall.
  5. trey
    trey
    1/2 off, men's designer sportswear collections at dillards. what the hell does that have to do with anything? [​IMG]
  6. motor mikey
    motor mikey
    from hanover pa
    Go to the local parts store and buy a exhaust tube expander. They expand when you turn the bolt with a wrench. Stick the expander in the con rod and start tightening the bolt. Works great. Make sure you turn it just far enough the break the cap loose. You should be able to work it off from that point.
  7. a/fxcomet
    a/fxcomet
    from Eugene, OR
    [ QUOTE ]
    FS
    [/ QUOTE ]
    Maybe I'm slow, but where do you smack the rod with the rubber mallet? You slide the big end over the large dowel, that is held in the vise, and smack on the side of the rod while pulling on the small end??
  8. Scotch
    Scotch
    Loosen the rod bolts a bit, and tap on them with that soft mallet...If they're studs with nuts on them, loosen the nut until it's flush with the end of the stud so you don't screw up the threads. If they're real bolts, just loosen them a couple turns to maintain good alignment while you separate them. If they get crooked, you could hurt the mating surfaces.
    There's actually a tool made to do this now. It's available from Mondello Performance and it works great, but you'd have to be bustin' lots of rods loose to justify it's purchase.
    Scotch!~
  9. Fastsporty
    Fastsporty
    Yeah, just apply pressure by pulling down on the small end, its the vibration of the mallet thats gonna knock the end off. Kinda like when you smack a brake drum. Them tail pipe expander thing will work too, but you have to put several layers of tape on the inside of the rod to prevent maring of the inside of the journals, I don't know if they sent it with bearings installled or not but either way you don't want to mar or scratch what the bearing sits on.
  10. a/fxcomet
    a/fxcomet
    from Eugene, OR
    Got one apart. I dont think the mallet I was using was vibrating enough. Got a PVC one.
    These have ARP Wave-Loc bolts. The "waves" extend into the cap a bit, makeing for a really tight fit. That is normal, right? I've never used these before.
