How do you tell a Merc crank??
Discussion in 'The Hokey Ass Message Board' started by 34Fordtk, Nov 17, 2003.
  1. 34Fordtk
    34Fordtk
    How do you tell a Merc crank out of the motor?????? Any easy things to spot???
    Thanks
  2. 34Fordtk
    34Fordtk
    BTTT Damn bottom of page 2 already
  3. Bigcheese327
    Bigcheese327
    5/8" cleanout holes. Ford cranks (and a few Canadian Merc, apparently) have 3/8" cleanouts. If you can fit your finger in, it's probably a 4" stroke.
  4. hatch
    hatch
    from house
    IN a very firm voice shout....CRANKSHAFT!!!....OUT OF THE MOTOR!!!!!!!!!!...if that doesn't work, try grounding it for a week.
  5. Smokin Joe
    Smokin Joe
    hatch, you may have to shout more than once, it may not hear you well. There's lots of sludge in a flatty bottom...
    On second thought, better not go there... [​IMG]
    And bigcheese is right, if you can finger it, it's a stroker... [​IMG]
  6. the front counter wieght has a dimple in the front of it. this is a merc 4" crank I have seen a web site with a web site showing a picture of the dimple but can't remember where. i'll look again and post a picture -------ray
  7. 34Fordtk
    34Fordtk
    Hatch I tried that and that SOB will not come out!! [​IMG] Your killin me [​IMG] Thanks the clean outs and the dimple sound like the easy way. I found an Econoline van with a bunch of Flatty stuff in it I am gonna score some of it tomorrow.
    Thanks much guys
  8. fuel pump
    fuel pump
    from Caro,MI
    You know what they say ..... you can always tell a Merc crank .... but ya can't tell it much [​IMG] [​IMG]
  9. Jim Marlett
    Jim Marlett
    The dimple only works for Canadian cranks. If the motor is still together, but the heads off, just measure from the deck to the piston at the bottom of the stroke. It's easy to measure the 1/4" difference. If it is out of the motor, the most reliable way is to measure the straight line length of the front heavy counterweight (second counterweight). If it's longer than 6 inches (like 6 1/8"), it's a Merc. If it's noticeably shorter than 6 inches (like 5 5/8"), its a Ford.
