Well here it is so far what do you guys think. Iam runnin a 9 inch rear 41' front axle,split bones, and brakes. a 57' olds 371 want to put a standard behind it if I can find a flywheel. Its chopped 4" channeld 4". Just keep workin on it when I get the time to.
I have 1" clearence between the cowl and the wishbone I think that should be enough. I would also like to put a different dash in it something in the 40's-50's not sure though.
Looks like decent progress. I just wouldn't want to hit a bump in that thing and smack those frame horns all to $%#@.
Your making great progress! How much suspension travel do you have in the front? From the angles of these pictures, it appears as though you'll need to put a spacer between the front leaf spring and the ch***is to keep the front axle from hitting the ch***is.
Yeah I was in a shop ther for about a year but I had a disagreement with the red neck next door and he brought over a gun so I figured it was time to move on.
