How far can I tilt my radiator back?
Discussion in 'The Hokey Ass Message Board' started by JPMACHADO, Feb 16, 2007.
  1. JPMACHADO
    JPMACHADO
    from Not Listed
    I have an aluminum radiator from Howe Racing. The vericle space it's in now is barely big enough. How many degrees can I safely tilt it back to gain some cleaence? Thank you once again to those smarter than myself.
  2. jusjunk
    jusjunk
    from Michigan
    you could lay it flat if the filler was extended and you had ample airflow.. think about it your not gonna loose that much coolant but it will be hard to fill if its too far back and you need airflow thru it..'
    Dave
  3. BigO
    BigO
    I'm not sure of the exact angle, but if it goes back past about 10-12 degrees the air gets trapped in the veins and creats enough pressure that the oncoming air p***es over the outside of the veins instead of going through them. I learned that from a friend who is an engineer and a Cup Car builder. If the air isn't going through the veins it isn't cooling. Hope this helps. Michael
  4. tattooedup37
    tattooedup37
    You can lay it flat if you want. As far as the airpockets from the previous post, Get a flush kit from your local NAPA and flush all the air out then put a remote filler in the hose if need be. The angle isn't the issue it is substantial airflow and will it be enough
  5. JPMACHADO
    JPMACHADO
    from Not Listed
    I think he's talking about air acutally p***ing in between them. externally. I can see what he means.
  6. BigO
    BigO
    But the angle is the issue. An in correct angle can stop the airflow. I'm not saying any angle other than a 90 degree angle is incorrect, but there is an area that the flow will stop until it p***es that angle range, then the air will start to flow again. Scratch Built asked what angle, not if he could lay it down.
  7. Just make sure that the flush kit (I'm guessing thats what you guys call the air bleeder) is at the highest point of the cooling system. When you fill it up open the bleeder and let the car run topping up the water until you only get a continual stream of water coming out. It helps if the filler is as high in the system as possible too. Either that or run a surge tank. Put whatever you do in the top radiator hose and make sure its above the head height.
    As for airflow through the core, a simple sheet aluminium chute will solve that. Or if you are willing thermo fans with an auto and manual on off.
    Doc.
  8. Edit,
    As for air p***age at any angle If the radiator itself is hanging in the open the air can spill over the sides of it. Making a simple air chute (Shroud) on the front forces the air to p*** through the core at all times without spilling over the sides. Now you have cooling flow.
    If you realy want to you can make small flaps to direct the air at the righ angle accross the core, like a set of cupboard louvers. Depends on how clean you need the set up to be.
  9. Unkl Ian
    Unkl Ian
    Bob East runs rads horizontal in his Beast Midgets.
    Part of the trick is in ducting the intake air properly,
    and slowing the air down before it goes through the rad.
    Big pulling fans would help on the street.
  10. Something to keep in mind,make sure the cap of your radiator is higher than the thermostat housing/top hose kneck on intake manifold.
  11. Unkl Ian
    Unkl Ian
    I've also seen rads mounted length wise,
    parallel with the frame rails.
    Sammy Swindell did this on his WOO Sprint Car,
    and some of the Big Block Modified guys have done
    this at Syracuse.
    We ran the radiator on about a 45 degree angle to the
    direction of travel,when we ran Can-Am back in the mid '80s.
    With a big NACA duct inlet,and proper ducting,the car never
    over heated.Didn't even have a fan.
    Carrol Smith explains radiator ducting in one of his books.
  12. Did anyone read my posts?? Howmany times are we gonna tell the guy the same ****ing thing?
  13. JPMACHADO
    JPMACHADO
    from Not Listed
    I appreciate all the advise. All I did know for sure was to have the filler neck as the highest point because water seeks its own level. I really only need to tilt it back about 10 to 15 degrees so I think from what I've read I'll be okay. I read some of the works that discussed ducting, but will stay away from that unless I absolutely need to. Once again I can't thank people enough for being smarter than me and willing to help me out.
  14. Were not smarter mate, just have some expierience in something you didnt.
  15. chevy400ci
    chevy400ci
    from Kansas
    most dune buggy guys have theres at about a 25 degree angle and in the backof the buggy.
  16. Big Dad
    Big Dad
    Ha, don't you hate it when someone asks a question
    Guy asked the other night ..
    "how thick are spacers for Mopar "b" engines to make a intake from a 440 "RB"fit
    I answer .500 ..
    next guy says 1/2 inch per side
    next guy says , intakes are inch wider ..
  17. Do you have room to tilt it forward?
  18. I feel the pain!
