how get 53 chevy speedo working????
Discussion in 'The Hokey Ass Message Board' started by milw53chevyguy, Mar 2, 2013.
  1. milw53chevyguy
    milw53chevyguy
    i picked up a 53 chevy bel air. it has a 350/350trans. the speedo wasnt hooked up when i baught the car. the cable is just zip tied underneith the car not connected. i was wondering how and what should i buy to get it working again. obvously it doesnt just tread onto the 350 trans. kinda new at this stuff. thanks
  2. silversink
    silversink
    If the trans. end of the cable wont match, call up a speedometer shop and have the end replaced with the right one. I just did this to my International pickup. It now has chevy hookup on one end and the stock on the other, but the spedo wont read right so they are making up a gear upgrade set up to get it close.
    The cable end was 10.00 labor and 10.00 for the parts, now the gearing I have no idea what they are going to come up with, in the mean time I drive with the Tach. and a GPS.
  3. chubbie
    chubbie
    find a right year speedo cable and pull the top end off and do the same with the old cable. epoxy or crimp the old end on the "new" cable. cost....
  4. HOTRODPRIMER
    HOTRODPRIMER
    Get in touch with these guys,,he's a hamber and has made me a couple of cables in the past. HRP
    www.speedoservice.com
  5. 325w
    325w
    Should just screw on. Make sure all parts are in the trans. If its short have the auto parts get you one longer.
  6. 49ratfink
    49ratfink
    did you try? I'd bet they are pretty universal or aftermarket speedos would require different adapters to go in different cars. if it is just too short go to the junk yard and get another one that works.
  7. Rusty O'Toole
    Rusty O'Toole
    Chev used the same speedo cable 1946 to mid seventies. So it might just fit.
  8. milw53chevyguy
    milw53chevyguy
  9. historynw
    historynw
    I'm using the same cable to run my 47's with my 700R4. I took my old speedo and cleaned lubricated at it connection point. I was able to run it with my drill to make sure all was good. The cable hooked up fine. I made sure it was lubed lightly also.
