Technical How I now attack brake line fittings
Discussion in 'The Hokey Ass Message Board' started by Andy, May 15, 2024.
  1. Andy
    Andy
    I have often been as frustrated as I can be with brake line nuts. They are often in really tight spots and really tight. I came up with a solution. I used a 3/8" crow foot tubing wrench on a 1/4" drive ratchet. I think it works great.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Been doing that for some time “now”.
    1oldtimer likes this.
  3. hotrodA
    hotrodA
    That’s a great tip. Didn’t ever think about a crows foot for tubing nut.
  4. manyolcars
    manyolcars
    Thanks for the information, Andy. Everything I know about brakes came from Andy
  5. Mr48chev
    Along with SnapOn tubing wrenches I have used a set of crows feet for Tubing like that for 50 years. One of those things that Carl Swingler (SnspOn man in Waco, Tx in the 70's) brought in off the tool truck and placed in my hand and said "you need these" that I bought on the spot.
    Those are one tool where "Almost as good as the good stuff" doesn't work and you need the good stuff. I've got some Craftsman line wrenches that don't get the job done like my SnapOn ones do.
  6. 67drake
    67drake
    from Muscoda WI
    I just had my crows foot tubing wrenches out a couple days ago. Power steering pump line in a REALLY tight spot.
    guthriesmith likes this.
  7. guthriesmith
    guthriesmith
    Yep, great way to get brake lines loose. My line wrenches are cheap junk so I often use the crows feet to do the job..
  8. 6narow
    6narow
    Crow's Foot.
    Very useful tool for doing hydraulic work.
    Somewhere I have a rack of those in 3/8" drive.
    For doing brake work, another extremely valuable tool is a "Line Lock".
    It is a small C-clamp with no sharp edges on the jaws.
    This keeps the clamp from breaking the wire core(s) inside the hose, but stops the Hyd. fluid from draining from the line.
    When you go to bleed the system, it just a little squirt of air and you're bled.
    Easy peasy.
  9. alchemy
    alchemy
    I’ve never seen a crow’s foot. Now I need to buy some.
    6narow and guthriesmith like this.
  10. They make them in regular open and flare. Just be careful, it's real easy to twist the line with a long handled ratchet on the end.
  11. Budget36
    Budget36
    I’ll be darned. I’ve an SAE and Metric set and never thought of using them for brake line fittings.
    Awesome idea!
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Works great on transmission lines at trans as well. Just be sure the step up to a 3/8” ratchet instead. ;)
    rockable and Budget36 like this.
  13. tb33anda3rd
    tb33anda3rd
    if I am changing lines, I just snip the line close to the nut with a diagonal cutter and use a socket and ratchet.
    2OLD2FAST and Rusty O'Toole like this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Have you ever forgotten to place the socket on the tube before flaring the new line? :)
    Wanderlust likes this.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    Like since 1962...:)
    badshifter likes this.
  16. 325w
    325w
    The nut needs to be the correct direction also!
  17. jazz1
    jazz1
    I crack em loose with small curved ViseGrips then carry on with line wrenches..much of which are metric now. My last build everything was SAE except for the front brakes, carb and fuel pump..
  18. tb33anda3rd
    tb33anda3rd
    once a year:D
