Technical How long will new gas last
Discussion in 'The Hokey Ass Message Board' started by glrbird, Apr 10, 2020.
  1. glrbird
    glrbird
    With this social distancing going on, I don’t drive anywhere. Will the gas in the daily driver last? It only gets driven about once a month before the virus. Now it’s been sitting about 2 mo. What do you guys think?
  2. triumph 1
    triumph 1
    It starts to go bad fairly quick but modern fuel injected vehicles don’t have as many issues with it compared to what carbureted engines do.
  3. TagMan
    TagMan
    I add Sta-Bil fuel stabilizer and fill the tank with Ethanol-free fuel just before storing it. I had a car stored that way for two years and it started up & ran fine. and that was a carbureted engine,
    Desoto291Hemi, loudbang and Dean Lowe like this.
  4. squirrel
    depends where you are, how the car is stored, what kind of car it is, etc. I've been ok here in AZ with gas over a year old in older cars in my garage. Late models with sealed fuel systems, a couple years. But in older cars, sitting outside for over 5 years, it turns into a mess.
    loudbang and Truckdoctor Andy like this.
  5. Tri-power37
    Tri-power37
    Gas with ethanol in it does not last as good as gas that is ethanol free.
    loudbang, Truck64 and Dave Mc like this.
  6. jimmy six
    jimmy six
    New gas? There’s new gas?
    I use 1 oz Sta-bil marine in every fill up and have for 7 years. A 15 gal fill up lasts about 2-3 months as I drive 2000 a year. Carbs and tank are clean and not any junk or build up in any thing. I have one of those gl*** AC 50’s fuel filters right before the carbs.
  7. Never2old
    Never2old
    from so cal
    I have been told that Standard Oil premium is will be good for a year.
    That’s one reason I always buy premium fuel.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. tb33anda3rd
    tb33anda3rd
    the new car have sealed fuel systems and the fuel lasts longer than in the older cars. if the fuel has ethanol in it and it is allowed to evaporate it goes bad in a month or two. the better the grade of fuel the longer it lasts. using stability and fuel additives does help. I manage a collection of over 50 cars, I battle this daily, your results may be different.
  10. BamaMav
    BamaMav
    from Berry, AL
    I had pure gas in my car when the transmission laid down. After it sat about a month, I decided it might be down a while, so I put a bottle of Stabil in it. Last summer, I decided I was going to drain the nearly full tank before I ran it with the newer motor, so I started pumping it out {electric pump} a couple of gallons at a time and using it in my lawn mower and 1955 IH farm tractor. It ran as good as fresh gas, so I decided to go ahead and crank the car on it. It ran fine in it, too. That gas was at least three years old or older and still looked and smelled like it did when I put it in. That Stabil works!
  11. junkyardjeff
    junkyardjeff
    I usually do not have any problems with the new gas in my older vehicles sitting over winter but trouble starts when it gets closer to a year,years ago I bought a parts car that sat for 16 years and I needed the gas tank from it and it was 3/4 full of gas so it went in along with the gas and it was still good but would not try that today.
    Desoto291Hemi, loudbang and Truck64 like this.
  12. tjm73
    tjm73
  13. B.A.KING
    B.A.KING
    I think i have said this before. I THINK it was Hot Rod Magazine had a article about Gas left left in carbs/tanks. This new **** will eat the aluminum of a carb if left for a while.
  14. gimpyshotrods
    gimpyshotrods
    Have you tried driving it?
  15. Dean Lowe
    Dean Lowe
    Pour a bottle of Sta-Bil in the tank. Why take a chance?
    jimmy six, Desoto291Hemi and loudbang like this.
  16. glrbird
    glrbird
    Thanks, it’s an 06 ford pu, so I guess Sta-Bill it is. Got some on the work bench, so I won’t have to leave the house. Thanhs for the info.
  17. tjm73
    tjm73
    That non-HAMB vehicle won't care about the fuel sitting in it's tank, fuel lines or injectors. It's designed for this fuel.
    I have a 1 year newer of the same truck. I just drive it to work once a week or so. Some times I take it to the hardware. Sometimes I just go for a drive. Mostly to keep the battery charged. If it sits for two months or longer, the gas won't matter much becasue the battery will probably be dead. Those trucks always have a power draw, unless you unhook the battery. It keeps the radio info memory going and they have an alarm system even if you don't use it.
    Anyway enough with the non-HAMB stuff. Let's get back to real hot rods.
  18. Bert Kollar
    Bert Kollar
    I recently built an off topic vehicle and stored it for two months. It wouldn't start and upon examination the carb adjusting screw had corroded and blocked the jet. Never saw a problem like that before
  19. BJR
    BJR
    HOW LONG WILL NEW GAS LAST
    Depends on how far and how fast you drive.:p
    gimpyshotrods and Hnstray like this.
  20. Bandit Billy
    Bandit Billy
    I wouldn't have a clue.
  21. partsdawg
    partsdawg
    from Minnesota
    Being in Minnesota I do have some knowledge of storing a vehicle for months. Have put cars in storage in October and fired them up in April. Never used Stabil or Seafome and never had a problem. I fill the tank with non-oxygenated premium fuel,disconnect the battery and bring the battery home to keep warm and on a trickle charger.
    A good premium gas with no ethanol/alchohol seems to last at least 6 months.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    there is no problem with non oxygenated fuel. My impala sat unused for 3 years (I know, shame on me) and fired right up last summer with non oxy gas. It is the ****py gas with 10% ethanol that won't last much more than a few months
