How long's your dipstick?
Discussion in 'The Hokey Ass Message Board' started by Gearhead Graphics, Nov 10, 2011.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    My dipstick is small,My wife ran off with some con named rod ,Just not enough friction,and to much clearance ,,,,,Lol As others posted drain oil fill with new ,And remark with hacksaw blade ,,,,,,,,,,
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I had to bump this ,Just went to page 2 and This thread was on top of I like big ****s 46 ford ,It just wasnt right............
  3. 69fury
    69fury
    from Topeka
    mine's as long as a cat's tail, as long as you measure them the same way...:p
    (from the ****hole to the tip)....:rolleyes:
  4. iwanaflattie
    iwanaflattie
    made think of this guy
  5. This sounds like a waaaaaaaay too personal question!!!
  6. hotrodladycrusr
    hotrodladycrusr
    or wet :D
  7. iwanaflattie
    iwanaflattie
    we are still talking about the oil measuring dip stick right???
    hotrodladycrusr you always finish my sentences,thhanks :)
  8. hotrodladycrusr
    hotrodladycrusr
    so you're probably not single right??
  9. budd
    budd
    my question is this, if you built or modified an oil pan so you now had to figure out what the oil level should be how would you go about this, what is the correct oil level in relationship to the crankshaft center line for any given engine, remember it is no longer a stock oil pan so quoting a volume won't work, it has to be a distance from the crank center or from the lowest point of the rotating ***embly.
  10. 69fury
    69fury
    from Topeka
    distance from the crank? below it a bit. Unless your building a high-end compe***ion mill, just set it so that the oil level is below your crank or windage tray when at rest.
    Set the pickup about 1/4- 3/8" off the pan floor and call it good. I weld legs to either side of the pickup so that if you ever cram the pan into something, the legs keep the pan from shutting off the pickup opening.
    I like baffles and trap doors, but the one i like the best is a shelf above the pickup that keeps the oil from climbing the back wall of the pan when launching the car. they make bolt on ones for sbc - oil pump baffle is what they call them, i think
    rick.
  11. mrforddude
    mrforddude
    I guess it's kinda like that whole "beauty is in the eye of the beerholder" type thing...
    So your dipstick to the left...good thing for your tailor to know...
  12. Gman0046
    Gman0046
    You know your dipstick is long enough when you get past the used part.
  13. aaggie
    aaggie
    The Volunteer Firemen have a saying, "it doesn't matter how big the hose is as long as you can put out the fire".
  14. BOWTIE BROWN
    BOWTIE BROWN
    Does this have anything to do with the **** popup Ryan mentioned ?
    "AND THE BOWTIE ROLLS ON"
  15. I dunno does pop corn and pop **** have anything in common?
  16. Iceberg460
    Iceberg460
    True, but it takes a long time to get to England in a row boat:D
  17. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    It may take a while, but isnt it about the journey not the destination?
    hell, I dont care if she gets there as long as I do
  18. yankbuilt
    yankbuilt
    Long enough to know how deep and cold the water is.
  19. falconsprint63
    falconsprint63
    from Mayberry
    mine's bigger than your is.........
  20. BOWTIE BROWN
    BOWTIE BROWN
    My ole lady does the dipstick booth at the county fair every year. She is an expert .
