Technical How low can you go without kickup
Discussion in 'Traditional Hot Rods' started by LarsL, Feb 20, 2026.
  1. LarsL
    LarsL
    from Norway
    How low can a 28/29 coupe go without a rear kickup?
    Can they be low enough with a Model T spring? Springs taken out?
    Any pics of fenderless coupes with that kind of drop.
    4 inch drop Axle in front.
    Thanks
    deadbeat and 51 mercules like this.
  2. Martinbuilt
    Martinbuilt
    This is what i have. 20260220_120003.jpg No kick, '29 sport coupe, model t spring with only 5 leaves left.
    6.00x16 tire.
    It might settle an inch or so once the car is more complete.
    With a 4" drop axle, you might have a ton of rake. Someone with more experience may jump in, though.
    deadbeat likes this.
  3. LarsL
    LarsL
    from Norway
    I hope i can see something like Eli’s car without kickup. This is so cool! IMG_5259.jpeg
    coupe33, Happydaze and winduptoy like this.
  4. 1935ply
    1935ply
    from peyton,co
    I have a model t rear spring with a reversed eye main leaf in my roadster and have a stepped frame to get it down where it looks right to me. IMG_0097.JPG
    winduptoy, rod1, Okie Pete and 2 others like this.
  5. pprather
    pprather
    This was stock rear frame. Clearance from frame rail to axle was about 2".
    Coilovers behind axle.
    winduptoy and Just Gary like this.
  6. A Boner
    A Boner
    If you want to push the minimum axle/frame clearance limit, adjustable bump stops would be s good plan.
    Just Gary likes this.
  7. Tim
    Tim
    from KCMO
    You’re going to land a 750/16 about 4” from the wheel well body line at the top center of the tire at lowest with spring over and no step.
    Only way I could see getting it lower with out stepping the frame would be to run the spring in front of the axle and move the rear cross member forward or cut it off and replace it with what ever your going to use forward of the rear axle.
    could do a traverse spring still, t buckets do this. Could do coil overs or quarter eliptics. Doesn’t really matter other than packaging challenges.
    rod1 likes this.
  8. alchemy
    alchemy
    Wheel and tire size makes a ton of difference in the way a car looks. The in-progress 29 with 16” wheels and 6.00 tires looks like a 4x4 compared to the chopped coupe with 18” wheels and 7.00 tires.
  9. krylon32
    krylon32
    from Nebraska
    Did quite a few customer 32 ch***is for Model A's with a 2-3 inch kick in the rear, flat front cross member, 4 inch axle and Durant mono leaf spring. I usually stuck with a Posie low A rear spring. My ch***is usually sat right.
  10. Mimilan
    Mimilan
    Put a 4" drop axle in the rear !!!
    Use VW bus portal axles and a bit of engineering
    winduptoy, Jeff34 and 5w Jen like this.
  11. trikejunkie
    trikejunkie
    from Scotland
    This is how mine sits , reverse eye spring in the rear reverse eye spring in front with an Okie Joe dropped A axle 20230615_134902.jpg
  12. LarsL
    LarsL
    from Norway
    So cool!!!
  13. krylon32
    krylon32
    from Nebraska
    These are a little off the topic but you can see what a mild kickup and a couple different front end tratments can do for stance. These modifications aren't that hard to do. Slamming a 32 ch***is just takes a little extra work.
    rod1 likes this.
  14. LarsL
    LarsL
    from Norway
    Thanks for the info Brother.
    I know how to do a step/kickup and i know its not that hard. I just wondered if one can achieve a cool look without that Mod? The Eli coupe i posted has spring behind setup, no step, just a slight C notch of the frame rail. And that stance screams kool to me.
  15. krylon32
    krylon32
    from Nebraska
    I've built a lot of 32 to A ch***is and sometimes you gotta cutum up a little to achieve your goals. I've had to raise he wheel wells etc. I did a ch***is for full fendered A ch***is for a 29 coupe a few years ago that used a flat front cross member, 5 inch axle and a slightly kicked rear with coil overs that sat really low but kept the stock floor. Can't find any pictures.
