Technical How Low Can Zephyr Go
Discussion in 'Traditional Hot Rods' started by mnathan660, Jan 11, 2021.
  1. mnathan660
    mnathan660
    Just acquired a 1941 Lincoln Zephyr 5 p***enger Coupe.
    Transverse leafs with 7.00 x 16’s have it sitting higher than my 1/2 ton truck.
    Without splitting wishbones, channeling or lots of frame work, how low can I expect to lower it with new springs?
    I would love 5 inches in the rear and 3 up front . . .
    Looking for realistic options, any links to traditional lowering are also much appreciated.
  2. lippy
    lippy
    from Ks
    Put a chrysler hemi or a caterpillar block in the trunk. :D
    31hotrodguy, 5window and mnathan660 like this.
  3. Squablow
    Squablow
    You can start the way a Model A guy would start, reverse the spring eyes on the main leaf front and back, remove one leaf from each pack, then reinstall and see where you land. I think the Zephyr has spring-behind rear setup so you might be able to add longer shackles and get a bit there too although I don't think you want to change the angle of the shackles too much.
    Also, lowering more in the rear is going to EDIT add some caster to the frontend, which could be an issue. Driveshaft tunnel clearance near the back seat may also become an issue.
  4. gimpyshotrods
    gimpyshotrods
    If I recall correctly, tires that size will hit the body in the rear if you try to do a static drop that low, and actually drive it.
    I cannot say for sure, but here is probably a spring shop in the Denver metro area. You can have leaf springs made that are built lower than stock.
  5. mnathan660
    mnathan660
    Thank you, we have several spring shops in the metro and that was the route I was exploring.
  6. mnathan660
    mnathan660
    Appreciate the advice, I was planning to find different springs and will play that route first with reversed, rearched main springs and rebuilt stacks.
  7. alchemy
    alchemy
    Lowering more in the rear will cause caster to be greater, not less. Not always a bad thing.
    If you don't want to do big mods, I'd say the first step is to crawl under the car and measure how much room from the top of your axles to the rubber bumpers on the frame. That is the answer to "how low can I go?" Then just figure out if you can do it all with spring reversing and flattening, or maybe you need shackle work, or maybe something more drastic.
    But, realize that riding on the bumpers will be a rough ride. That's why lots of guys use dropped axles in front and C'ed frames in the rear.
  8. mnathan660
    mnathan660
    Thanks for the tips.
    These are all good things to consider.
    To clarify , I am not looking to take this thing into the weeds, and with it currently sitting 13” of height off the street to the lowest point of the car it should come down some.
    There is about 12” of clearance from the top of the tires to the inner fenders, and with the driveshaft, wishbones and turn radius I am fairly sure 5 - 6 inches will not cause interference and a little positive caster would help.
    Just want a little less overall height, no gap in the front tire to fender lip aesthetic, and a slightly lower rear to front drop.
    kidcampbell71 likes this.
  9. lucas doolin
    lucas doolin
    Have someone on the HAMB drop the front axle.
    mnathan660, kidcampbell71 and 302GMC like this.
  10. 302GMC
    302GMC
    from Idaho
    A set of 15'' wheels with 6.70 tires would drop it 3'' minimum, probably more.
    mnathan660 likes this.
  11. Pretty low, check out our video on an LZ.
    mnathan660 and Bandit Billy like this.
  12. Squablow
    Squablow
    You're right. I edited my post accordingly.
  13. 38Chevy454
    38Chevy454
    A dropped axle in front will get you approx 3 inches, with no other changes. Reverse the eyes and you are at 5 inches roughly, and still decent susp travel so not sitting on the bump stops. The dropped axle also can pull the wheels in a little, making them more centered in the front fenders, so less issues with tire clearance than when more near the outer edge.
    Rear is going to be tougher, as you can only do so much before susp is on the bump stops. Longer shackles, dearched springs, are all ways to get the rear down. Eventually you will need to consider the frame mods. For sure the Zephyr coupes look much better when lowered down. For that matter most all cars seem to look better when lowered, LOL.
  14. mnathan660
    mnathan660
  15. mnathan660
    mnathan660
    Finished initial lowered car about 3 inches up front and 5 inches rear.
    9E677E5C-7026-4969-94D9-FB61E995B380.jpeg l
    Removed spring leafs:
    - 6 front (had 2 extra leafs)
    - 4 rear
    Fabricated and replaced rear lower crossmember with a flat version made of 3 inch 1/4 square tube.
    Wonder why no one has mentioned 2 piece crossmembers before?
  16. jetnow1
    jetnow1
    from CT
    Looking good.
  17. Fortunateson
    Fortunateson
    That's one cl***y looking car. I don't mind taildraggers but what you have done looks great!
  18. Kirkster
    Kirkster
    Can you post a pic of the rear suspension showing modifications done. Thanks,Kirk
  19. Lättähattu
    Lättähattu
    from Finland
    I have dropped one Zephyr axle. My jig has been made for Ford axles with king pin inclination 7 or 8 deg. Lincoln has KPI only 4deg, so i could not drop it more than 1 1/2" over stock one (total drop little more than 3 inch) before axle was hitting the top beam of the jig. The drop also narrowed axle 1 5/16" , which might be good thing to avoid tire to fender rub when doing tight turns.
    Adriatic Machine, pprather and rod1 like this.
