how low is too low on a radiator?
Discussion in 'The Hokey Ass Message Board' started by johnnygringo, Mar 25, 2004.
  1. johnnygringo
    johnnygringo
    from Nashville
    got a very clean radiator off of crestliner and was wondering the best way to get it to the heighth we want
    pics show where i measured to and that puts it 5 and a 1/2 inches off the ground...which seems low
    so should i...
    lower the mounts on frame?
    lower the mounts on the radiator?
    chop it and if so anybody here do it?
    go with another?
  2. MBL
    MBL
    Chopping the Rad is something that is maybe not the easiest or cheapest thing to do...or from what I am told. I think the trick is to find someone willing to do it for a reasonable price. You might do better to use a mustang rad and add bungs to it. Thats what I am doing with my T.
    tim
    MBL
  3. flt-blk
    flt-blk
    from IL
    That's plenty of clearance, I probably have 3.5" and have
    never hit anything big enough to do damage.
    If you're worried about it build a little nerf bar to
    protect it.
    TZ
  4. Crestliner
    Crestliner
    The t-bucket I just sold had the radiator that low.
  5. Smokin Joe
    Smokin Joe
    Yea, flt-blk, but it's pretty hard on that poor lizard!
  6. DrJ
    DrJ
    Roth's "Outlaw" has the radiator that low, behind the fiberglass nose.
    I think If I was running it that low I'd weld up a "gravel shield" mount for it as thick as the frame metal that encased the front of the bottom tank.
    I'd do this because I have a lower A arm on my '60 Elky that is bent in about an inch from hitting something and I ran over a cinder block on the freeway once with a '71 Caddy and the block disintigrated when it got hit with the front cross member, but if the first thing it hit had been the radiator.... well, you get the picture.
    Make a "box" under there for a mount.
  7. Eyeball
    Eyeball
    My roadster is set up similar.
    My radiator does not hang below the frame but the grill shell does.
    I have around 2.5"-3" clearance on it and have not hit yet.
    One thing you have going for you is that the axle is in front of the radiator so it will start up hill before your radiator does.
