Art & Inspiration How Low Should I Go?
Discussion in 'The Hokey Ass Message Board' started by paul55, Mar 3, 2018.
  1. Hot Rods Ta Hell
    Hot Rods Ta Hell
    To Hnstray's point, parked on gr*** photos visually lower the car 2=3". Can you post a photo taken with the car on pavement with the camera positioned 2 feet from the ground (tire top height)?
    (Also, the car looks significantly lower in front than your avatar, so I ***ume you've already lowered it a bit?).
    Having said that, I like it as is.
    Things to consider;
    A 15" rim up front (all things being equal in tire size) will raise the front 1/2". Your disc brake conversion may be incompatible with 14" wheels anyway.
    Dropped spindles vary in quality and fit (cheap overseas, vs. USA made).
    Many dropped spindles and/or disc brake conversions widen your track width (more tire rub issues). I believe at least one narrows your track. There are different disc brake conversions for both stock spindles and dropped spindles, so if you buy a kit for stock spindles it won't fit dropped spindles.
    Hit the Tri Five boards for reviews, fit, etc.
    I'd recommend you buy the dropped spindles AND disc conversion kit from the same manufacturer (ie: Heidts).
    Hnstray likes this.
  2. paul55
    paul55
    from michigan
    Thanks for all the input/info guys. Appreciate it!! Paul
  3. traffic61
    traffic61
    from Owasso, OK
    Leave it be man. It is most excellent as it is.
  4. A Boner
    A Boner
    Drop the front, leave the *** end as is.
  5. when it sparks going down the road its perfect
  6. RMONTY
    RMONTY
    Whatever you do, DON'T do this! :eek: chevroletnomad1955crash12bc.9199.jpg
    Ron Funkhouser likes this.
  7. paul55
    paul55
    from michigan
    Yes, I avoid all construction sites! lol
  8. low budget
    low budget
    from Central Ky
    Yeah,It will turn into a 2 door wagon just before the accident but will be ruined anyway so...
    The home improvement Nomad does appear to be a nice one tho.
  9. Gman0046
    Gman0046
    My 64 Biscayne with 2" drop spindles and short coils in the back is just a little too low. I've got to be real careful to prevent bottoming on speed bumps and the drive shaft hits the floor with too much weight in the back. Probably should raise it up slightly but it looks great the way it is. IMG_0812.JPG
    32Dan likes this.
  10. southcross2631
    southcross2631
    Put it back the way t was . I liked it jacked up.
  11. loveoftiki
    loveoftiki
    from Livonia,Mi
    Jack it back up...
  12. paul55
    paul55
    from michigan
    I know, I liked it raised up, slicks, fenderwell headers, roll bar, etc. too. However, it was time for a change, and make it more useable. I want to start taking it on some longer trips. With the front raised and the slicks, at 70 mph it wanted to "dance around" a bit.
  13. Personally, I'd leave it pretty much the way it is now. It's a pretty fine line between being usable and just that little bit lower.
