how low with fenders model a
Discussion in 'The Hokey Ass Message Board' started by peter schmidt, Jul 19, 2013.
  1. peter schmidt
    peter schmidt
    from maryland
    just wondering how low i can go with my 31 coupe with fenders i have a stock spring i reversed the eyes on and a 4 inch drop model a axle and a stock 33 axle. will it be to low in the front with 6.50 16 and the drop axle? the backs just getting a t spring with a couple leafs renoved running 7.50s on the back. i can save the 4 inch drop axle for my coupster if i have to as it wont have fenders.
  2. Jalopy Joker
    Jalopy Joker
    post some pics. whatever axle you use make sure that it will center wheels under fenders.
  3. Fenders
    Fenders
    Well I have a 4" drop front axle, reverse eye spring, 205/70R15 tires (yah, I know...) -- you can see it in my avatar and I don't consider it real low in the front.
    Re jalopy jokers post, the axle is a ch***is engineering 47 inch.
    edited to add recent photo.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Not a Model A but I used a model A front cross member instead of the 32 which gices it a extra inch drop..used a reverse mono spring and a 4" axle 5.60 x 15" tires,,it's not too low. HRP
  5. creepjohnny
    creepjohnny
    No it won't be too low. That's the set up I did and it looks great. Just mind your high point driveways or short and high speed bumps. Think the lowest point of the car was where the front fender and running board met, was about 6"-7" off the ground.
    <a href="http://s273.photobucket.com/albums/jj211/creepjohnny/?action=view&current=null_zps177aa4f7.jpg" target="_blank">[​IMG]</a>
  6. Dean Lowe
    Dean Lowe
    With a 4" dropped axle and reversed eye spring, I would be surprised if the tires you want to use didn't rub the fenders. I'm running a 4' axle and reversed eye spring with one leaf removed. My tires are 145-SR 15's and they slightly rub the fender brace turning into a driveway. The tires are only 23" tall.
  7. peter schmidt
    peter schmidt
    from maryland
    ill give it a try with what i got hopefully it all fits good most people dont run 6.50s in the front but its what i had and i like them. thanks for the replys and pics.
  8. badshifter
    badshifter
    Your front tires are going to hit for sure. Less drop or smaller tire.
  9. BenD
    BenD
    Alliance Member
    4:50 or 5:00 on the front, it is a Hot Rod after all.
  10. scrap metal 48
    scrap metal 48
    4" dropped, 46" wide axle with mono leaf spring and 5.60x15" tires..
  11. tedley
    tedley
    from canada
    4 in drop, revered eye, 15x6 rims 165. Basicly a vw tire. Axle a bit wide but no problems until a drive way approach with a incline on a sharp turn. But minor.
  12. 500-525 tire will fit better
    my 29 had zero turning radius with the bigger tire
    tk
  13. peter schmidt
    peter schmidt
    from maryland
    i like the size of my tires it doesnt have to be real low just want to get rid of the gap i guess ill ***ebly it loosely with the 33 axle and reverse spring and if its not low enough use the drop axle and reversed spring if its to low with that i can throw the stock spring back in to bring it up some. heres a pic of tge car now i just want the fender gap smaller. [​IMG]
  14. tedley
    tedley
    from canada
    My axle is just as wide as yours. It's from a 34. Look at pics above from my last post.
  15. here is mine with stock wheel n tire.
    33/34 axle , reversed eye, 2 leafs removed
    and the a 500-525 tire
  16. ty johnson
    ty johnson
    Saw this one and it was dam low.
    my ol 28 with a 2" drop posie reverse eyed spring with 1 lea removed and a 36 axle dropped to about 4 1/2's and a 145/15 tire.
  17. bgaro
    bgaro
    yup, i think you gotta mock it up and have a look see.
  18. Fenders
    Fenders
    Good plan, let us know how each iteration works out.
