Customs How low.....
Discussion in 'The Hokey Ass Message Board' started by Never2old, Apr 22, 2013.
  1. Never2old
    Never2old
    from so cal
    ........................should I go?
    No bags & no pumps!
  2. Jalopy Joker
    Jalopy Joker
    low enough to get in and out of driveway without dragging frame and oil pan. not so low that you ride gets stuck in the middle on a parking lot speed bump, etc
  3. Fenders
    Fenders
    Is this a serious question?
  4. 4rod
    4rod
    X2 if you can't get out off your driveway you can't go to far
  5. dana barlow
    dana barlow
    from Miami Fla.
    My guess,That size wheel base needs 4in. if it was shorter like a camaro 3in.
  6. KandN Kustoms
    KandN Kustoms
    How low?
    ALL THE WAY!!!!!
    :cool:
  7. hoop98
    hoop98
    from Texas
    Some info;
    I have some alternate springs if you are interested...
  8. jcmarz
    jcmarz
    from Chino, Ca
    3" in the back, 2" in the front so it will sit level. The back is higher than the front.
  9. Never2old
    Never2old
    from so cal
    It was meant to be a rhetorical question. I was expecting someone to ask if I was getting a nosebleed driving it at stock height.
    I cut one coil on my Impala SS back in '65, it looked right and went everywhere. I guess it went down about 2 1/2".
    the lowest point is the front of the moffle (we're pretty close to Tijuana here so some Spanish rubs off) at 7". I guess I can go lower if it aint right.
  10. bigpokie
    bigpokie
    Why not bag it ? You really don't have to do major modifications, if that's what your worried about. And you can have the low with a good ride and if it's to low raise 'er up
  11. looks great the way it sits if it were mine id raise the rear a couple of inches maybe
  12. Mr48chev
    He nailed it. It's real embarr***ing to have to tell the two gals that you and your buddy picked up while out cruising around that they will have to get out so you can get unstuck from the speed bump in the parking lot. At least it was for me:D about 50 years ago.
  13. nwbhotrod
    nwbhotrod
    from wash state
  14. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Because bags are for groceries.
    I agree with Jcmarz, a nice level stance would be good.
  15. Never2old
    Never2old
    from so cal
    Bags are not traditional.
  16. ol'chevy
    ol'chevy
    Ever heard of Air Lift? Bags go way back. Maybe not in this configuration, but they are old tech.
  17. jcmarz
    jcmarz
    from Chino, Ca
    Of course bags go way back, Grocery Bags, Old Bags, Baggy Eyes.:D
  18. 1951Streamliner
    1951Streamliner
    from Reno, NV
    "Bags go way back" That is correct.
    Using bags to achieve a broken looking mini truck stance with your frame laying on the ground does not "go way back"
  19. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Sorry for getting off topic for the thread, but this whole air bag thing on a TRADITIONAL FORUM has been bugging me.
    I think you should drop it 3-4 inches to give it a level stance.
    Then throw some astro supremes and skinny whites on it.
    then CRUISE
  20. mattrod68
    mattrod68
    i vote for 2 pumps, but if not keep lowering till it just barely s****es and youll be close.
    oh an if the oil pan sits lower than the crossmember please raise it a touch!
    matt
  21. I had a 63 bel air and lowered it 3" all around (w/ lowering springs from Ecklers). Looked great, drove great.
  22. slammed
    slammed
    Have the lower control arm stepped 2". Cut one wrap (2") front is done. Rear coils can be trimmed at both ends for a full wrap or 1 1/2, 1 3/4 wrap drop to attain a slight forward rake. A rear sway bar may be modern, but you will love the dramatic change in handling.
  23. Scotts Enterprises
    Scotts Enterprises
    x2...
  24. bigpokie
    bigpokie
    more the reason for the air ride
    you can add bags to lower a vehicle and not cut it up to have a "broken mini truck stance". it doesnt have to hop or drag frame, throwing sparks everywhere either. its a easy way to have the best of both worlds. traditional or not its preference
    well in that case, low enough were you have to be careful getting in and out of your drive way
  25. hotrod40coupe
    hotrod40coupe
    Does California still have a lowering law? If they do, don't go lower than allowed because they will bust you.
  26. jcmarz
    jcmarz
    from Chino, Ca
    old wives tales. May be true 40-50 years ago.
  27. Study a bit of history from over fifty years ago:
    http://www.kustomrama.com/index.php?***le=Ala_Kart
    "The suspension system is all made up of 4 coil springs with adjustable air bags."
  28. jcmarz
    jcmarz
    from Chino, Ca
    Here's the definition of "tradition"
    http://dictionary.reference.com/browse/tradition
    The ALA Cart had air bags but it wasn't a common method of lowering cars in 1958 as it is today. What's in common use, in popular use is what defines tradition and tradition is the continuity of that common, popular use.
    peace:)
  29. busajack
    busajack
    from wy
    Castors under the bumpers.
