How many have set themselfs on FIRE !
Discussion in 'The Hokey Ass Message Board' started by ChefMike, Mar 14, 2012.
  1. Probesport
    Probesport
    I've gotten used to catching fire, and like some others in this thread mostly due to grinding. I always have a damp rag around when welding/grind/etc so I usually just grab it and put out the flame and continue on with smoldering textiles.
    My wife stopped buying me flannel shirts, however I still haven't picked up a shop apron so we each have our limits.
  2. Hotrodbuilderny
    Hotrodbuilderny
    I fired up a 68 camaro so I could pull it in my shop, I stuck a gallon jug in the front,ran a hot wire to the coil, because originally it would not spark, cranking 12 volt outside wire on starter wasn't on.This car was a blowout, in for everything floors, quarters windshield area, everything,nyway I get the car to fire and I see water spraying in my direction (or so I thought when I realized it was gas) turns out the clamp on the rubber line at the carb, had been either left loose or loosened previously. I grabbed the fuel line to stop it from spraying back towards the distributor, which in turn soaks my sweatshirt just as it goes ****. I have now become the Torch, tried pulling the sweatshirt off which only increased the flames.Ended up doing the stop, drop, and roll, to get it out. Some really nice burns on the face chest and arms .Never ***ume it doesn't work out well.
  3. Bugsy
    Bugsy
    from Kansas
    This made me laugh as I JUST did this two days ago!!
    Frayed coverall pants + Testing an old, electric fuel filter that spings a leak = no more frayed coverall pant bottoms!
    It caught the garage door frame on fire too and damn near my old dog when I chucked the flaming filter out in the yard!!
    I'm used to this sort of bonehead thing but it's nice to know I'm not the only one that's done this!
  4. Crystal Blue
    Crystal Blue
    Head bowing down, hand held up high, yes sir....... guilty......and often !
  5. tommyd
    tommyd
    from South Indy
    Burned my foot pretty good once. So you should'nt weld with tennis shoes on? Huh, I never made the connection.
  6. ChefMike
    ChefMike
  7. 49ratfink
    49ratfink
    ... couple of tales here where someone is cranking a motor while pouring gas down the carb.
    What are you guys thinking? that thought has never even crossed my mind.
    would have been a good one with a car I have been working on lately. couldn't get it to start or even cough like it is trying to start. little gas down the carburetor, back inside to crank it over and woosh! ... big ol flame about 2 feet tall. Biggest backfire I have ever seen. I would not want to be the guy holding a gl*** jar full of gas around that one.
  8. I set myself on fire 3 times, once when grinding and twice when welding.
  9. Deuces
    Deuces
    Ummmm..... Now why would you want to set yur *** on fire???... :confused:
  10. Heo2
    Heo2
    more times than i can remember both welding
    related and as a kid playing with blackpowder,
    gas, and acy/oxy baloon bombs. they realy
    remove hair when they blow up close to your
    face
  11. dad-bud
    dad-bud
    I was welding away on my back with my MIG under an old convertible - on stands, so not a lot of room.
    Gettin' covered on sparks and stuff, smellin' burning cotton, etc not thinking much of it, when out of the corner of my eye, I see some flame.
    Hmmmmm, I thinks, shouldn't be no flame over there!
    Don't ask me how, but a polyester car cover is well alight.
    I didn't even have time to swear - I needed to crawl out the other side of the car, over lots of sharp **** (yeah, I shoulda been tidier), got to my feet and headed around to where the flames were gettin' higher.
    As you can imagine, every stupid bike, mower, chair, spare rubbish that the wife and kids could put in my way was like a tactical response group training course.
    By now, I have regained the ability to curse, but realised I didn't have anything to use to put the fire out, so I set to, trying to stamp it out with my feet.
    Stupid idea to wear trainers that night.
    The flames are getting higher, I'm dancin on the stupid cover, wishing that I'd worn the asbestos Reeboks, instead of some manmade training shoes.
    After about a minute, there's melted car cover stuck to me, stuck to my shoes and stuck to some carpet I'd had leaning against the wall nearby that had decided to get in on the fun.
    In the end, I was lucky, I didn't get burned (skin), but got some hair on my legs singed off, my shoes ended up with melted car cover and carpet welded to them.
    It stunk like hell in the garage, but when the excitement settled, I sat down and decided I'd been very lucky that I didn't lose a lot more than a car cover and a pair of shoes.
    Stupid, but it was a good lesson.
    Now I clear a path out in case I've got to get out, and I do check what's around before I start.
  12. Heo2
    Heo2
    Brother of a friend was grinding some kind
    of bracket out of a piece from a vw gearbox
    got the coverall ful of grindingdust. Then he
    started to grind some steel. Bawooom and
    a bright flash and him screaming and pulling
    the coverall off so much magnesium in the vw
    alloy so it lighted up
  13. zzford
    zzford
    Yep, I have done it a couple of times. I've not tried to ignite myself near as many times as my ex-wife has.
  14. Wild Turkey
    Wild Turkey
    Didn't set myself on fire (this time) but did start a nice garage fire while grinding.
    LOML had moved the lawn mover gas cans and "covered" them with a plastic tarp for some reason.
    Grinder sparks are hot enough to melt through the plastic tarp and still set the gas underneath on fire.
    Glad it didn't explode!!
    Caught reflection of flames in my visor and grabbed hose before anything except the tarp and one gas can burned up:eek:
    And yes, there are a few scars on my hide from various hot things:rolleyes:
    I was welding some pieces together for my brother one day and noticed the inside of my cotton shirt's sleeve was getting holed by the slag. Grabbed a spray bottle of water and kept shirt wet while I finished the production run:cool:
  15. krimsonghost
    krimsonghost
    I learned that the hard way as well!
  16. Greaser Bob
    Greaser Bob
    This one time at band camp, I was in an underground parking garage in Hollywood,Ca. I sprayed my Nova trunk with that black paint that has white specks in it, but it was dark and I fired up my zippo to get a better look. WHOOSH!! My head is on fire and now I'm rolling on the cement floor like an idiot! Hair mostly gone-check. Eyebrows completely gone-check. Read the spray can, "Contains butane"-check.
    ****in idiot-check!
  17. Does a really good singeing count? I have however set others on fire...
  18. butch70462
    butch70462
    which time LOL Butch
  19. Yup, also, don't grind while wearing a Patagonia Polypro sweater!:eek::eek:
  20. Probesport
    Probesport
    I will admit I had to google that one, I had no idea what that meant...
  21. redsteely
    redsteely
    from Phoenix az
    My story is not car related and short. It involved a potato gun, whiskey, and pvc primer. :)
    Wish I had pics. Burnt both hands pretty good and almost the hole front of my shirt along with some chest fur.
    As I look back it was pretty darn funny. Boredom+Whiskey=Random Injury.
  22. damagedduck
    damagedduck
    from Greeley Co
    here's one from another thread::
    Re: Help my heads on fire and other shop attrocities
    with over 20+ years of welding under my belt,i could begin tell how many time i started my *** on fire,or some FANG starting their *** on fire,i'm well trained in the smell of burning cotton!
    one of my first WTF moments was when i was around 13,in a South Dakota ground blizzard, some jack wagon came into the yard where i worked wanting a ****** out of a car{RIGHT NOW!} so i get elected to go fetch it so i get the bright idea to use a concrete saw with a fiber blade to cut it out-the car is on it side.
    about 5 minutes into i smell burning cotton--look down & my crotch is in flames without thinking i start to smacking my junk--yep right in the nuts!:eek: when i get back to the office every body is ******* themselves!even the guy who wanted the ******,he asks 'where my ******?'--my answer
    F:mad:CK YOU!go get it yourself!
    they said they sat & watched the whole damn show from the safety of the office,& were taking bets on what i would do to screw it up. *******S
  23. BACAGrizz
    BACAGrizz
    Was welding one time in a cold shop and all of a sudden I noticed my knees were getting warm. I had lit the fringe on the frayed holey knees of my Levis. Happened twice more before I stopped wearing holey pants to weld.
  24. LowKat
    LowKat
    don't keep matches in your shirt pocket
  25. BJR
    BJR
    Richard Pryor did it.
  26. JD Miller
    JD Miller
    How about carb cleaner sprayed directly in the eye....
    All welders catch fire at some point. Sparks down the ear c**** realy **** too.
  27. studeboy
    studeboy
    While changing the fuel pump on an OT car I spilled some gas on the floor. The next job in the bay needed some welding done. I set my shoes on fire as soon as the sparks hit the floor under the car where I was standing. The secretary steps out of the office and starts yelling, completely freaked out. I looked down and started laughing as I could just start to feel the heat on my legs.
    Watched a coworker try to burn a customer car to the ground with a can of carb clean trying to locate an intake leak. Bad ignition wire set it off.
  28. MeanGene427
    MeanGene427
    from Napa
    A friend got himself a couple weeks ago, soldering under his car, *********** in his shirt pocket, he's in the burn unit in SF right now, got his hand, arm & chest, had his first skin graft Monday, at least one more to go. Gonna be OK but lucky.
    A old guy that worked for my gramps in the 60's was cleaning up the shop, trying to keep busy in the winter, and in those days everyone just used an open bucket with a brush and some gas, right? Used to be my "job" as a little kid, go outside and wash the parts.. So he's washing away, already washed the bench grinder (!) and desides to clean the upright coal stove in the corner- while it was burning... VERY lucky the bucket was almost empty, got burns on his hand & arm, and could have burned the shop down
    That 'ol guy was kind of a sad sack type, a little punchy you could say and not the best of luck, and he went to work for an outfit in town that built potato harvesters as a welder, worked there a couple years, and the simple repe***ious work suited him pretty well. So one morning at work he heads off to the ****per, and after a while the other guys noticed he hadn't come back and went looking for him, found him- he had had a heart attack and died on the throne, sitting there peacefully staring ahead
  29. Deuces
    Deuces
    I use those same naughty words every day... :rolleyes::eek:
  30. Ironshot
    Ironshot
    from Las Vegas
    I've set myself on fire something like 5 or 6 times over the years. The worst was getting about a pint of diesel spilled on my brand new Carhartt overalls and burning the left leg on the overalls off up to the knee. My red, sore, swollen leg was hairless for a looong time. :)
    Kinda funny now.
