Hot Rods How many holes in your axle ????
Discussion in 'The Hokey Ass Message Board' started by Toqwik, Sep 4, 2009.
  1. Toqwik
    Toqwik
    I'm getting ready to drill the front axle on my 31, and was wondering how many holes you put in your axle. Pictures are appreciated....
  2. Ghost28
    Ghost28
    Check out the thread ***led (32 chevrolet coupe build) He just drilled his axle...John
  3. I did 17 holes about 1 1/8" Dia. if I remember correctly, in a Ch***is Engineering Axel.
    HemiDeuce.
  4. moses
    moses
    13 would be the lucky # for me.... jeffrey
  5. Russco
    Russco
    from Central IL
    I've done a few superbell axles I put 14 holes in them (not drilling in the emblem) 7/8 hole on 2" centers I also made a simple jig using 3 2" washers cut flat so they fit down in the recess of the axle and tacked together.
  6. 29paul
    29paul
    14 Holes 7/8 hole [​IMG]
  7. TexasHardcore
    TexasHardcore
    from Austin-ish
    6...the ones Henry put there.
  8. Toqwik
    Toqwik
    Mine is a heavy Ford one also....
  9. dirtbag13
    dirtbag13
    i put 13 7/8ths holes in mine !
  10. PeeVee
    PeeVee
    13 for me too. Thought it would be a good omen.
  11. 60 Belair
    60 Belair
    lucky 13 ​
  12. donut29
    donut29
    from canton MI
    Check out the tread (what would you do with a 32 axle and bones this is what I did) I would do a link but I have no clue how to do it
    I did 19 1 1/8 hole's on 1.777 center's that leaves 5/8 between holes
  13. Toqwik
    Toqwik
    Anyone have a pic with 13 holes, I like the 13 idea............
  14. dudley32
    dudley32
    7 and 7 the perfect number....
  15. fab32
    fab32
    Did 13 in a Ch***is Engineering Forged,4" drop. Cut out some discs out of a light cardboard/ heavy paper and lay them out in the recess of the axle.. Move them around (change the distance between them) and change the number. You'll come up with a combination that catches your eye.
    Frank
  16. HotRod31
    HotRod31
    15 holes 1-1/8"dia.
  17. 296 V8
    296 V8
    from Nor~Cal
    For doing a mock up for hole layout..I use 3/8 flat washers. I do a min. of 17 and a max. of 21 on 28 to 36 axles.
  18. Toqwik
    Toqwik
    296, What size holes are those?
  19. a.y1320
    a.y1320
    19 holes, 1940 ford axle
  20. i know they say you not to drill a cast axle(a completely different debate), but how many have people drilled in a super bell axle?
  21. yekoms
    yekoms
    Same here...
  22. 296 V8
    296 V8
    from Nor~Cal
    The one's in the photo I think were 1''
    Iv done some with 7/8 and some heavys with 1 1/6 and 1 1/8. Whatever the guys want or whats sharp at the time :rolleyes: :)
  23. gasserjohn
    gasserjohn
    using this since 67
  24. Toqwik
    Toqwik
    Anyone have a straight on pic of 13 holes?
  25. Russco
    Russco
    from Central IL
    I personally have done 3, using A 7/8 hole saw slow and NO lube (seriously it works better without cutting oil)
  26. realkustom51
    realkustom51
    small holes. Axle never perfect so holes not perfect.
  27. so, how many hole did you drill in the 3 you did???
