Technical How many leaves in front spring?
Discussion in 'The Hokey Ass Message Board' started by evintho, Apr 1, 2017.
  1. evintho
    evintho
    It's a '38 Ford spring. Did I remove too many leaves? Should I add some more? Not much of an arc in it. The whole car probably weighs 1500 lbs. Also, I've got 11 degrees of caster in the front end (forgot to figure in engine weight when I built it....duh), can I get away with this or will I push going into corners?
  2. swade41
    swade41
    from Buffalo,NY
    I have yet setup a spring by visual alone, I always use compression and rebound to determine the amount of leafs.
  3. ROADSTER1927
    ROADSTER1927
    Your spring looks fine but how it flexes is most important . Your caster is a little extreme, but try it and you will know. Gary
  4. Sheep Dip
    Sheep Dip
    from Central Ca
    I think most of those old Ford front ends where set between 4 and 9 degrees on caster, mine have always been set at roughly 5-6 with no issues. 11 might be a little excessive.
  5. scrap metal 48
    scrap metal 48
    At 11 degrees, you'll go straight, down the highway.. I agree with above poster, try it, you should be fine...
  6. D.N.D.
    D.N.D.
    I had 5 in my tube axle in my 37 g***er and it did not want to turn too good, you might have a bit way too much
    DND
