How many teeth do I need for speedo. driven gear?
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Nov 29, 2013.
  1. 36tudordeluxe
    36tudordeluxe
    Have a 4 speed top loader with a 3.54 in the back and 235/75/15's and 21 tooth driven gear, calculator says at 60 MPH indicated am actually going 68 MPH with this setup. I read somewhere on here that a tooth was worth about 2.5 MPH; so would 3 more teeth be about right?
  2. squirrel
    fewer teeth maybe?
    8 / 60 = 13% error
    .13 x 21 = 3 teeth you need to reduce
    so yeah, try a 18 tooth
    beware there are different angles of teeth on Ford speedo gears, left and
  3. 36tudordeluxe
    36tudordeluxe
    Right, I know about the gears being right & left; I divided 2.5 into 60 and got 24, so I thought add 3 teeth?
  4. synchro7
    synchro7
    For my A, I went to NAPA, gave them the trans, tire size and diff ratio. They came up with a tooth count for the driven gear. I checked the speedo against the mile markers for 50 miles,it's within 1%.
  5. e1956v
    e1956v
    Alliance Vendor
    68-60=8
    8÷68=.11765×100=11.76% slow
    Ford gears are roughly 5% per tooth so 2 Teeth less will speed it up 10% .
    Squirrel was very close. As usual.
  6. 36tudordeluxe
    36tudordeluxe
    Well, that makes it real simple! Still would like to know how they figure it. Thanks for the help
  7. charlieb66
    charlieb66
    "I read somewhere on here that a tooth was worth about 2.5 MPH". If that is true, some of my Southern cousins could only get up to 7.5 mph.<!-- / message -->
  8. e1956v
    e1956v
    Alliance Vendor
    :DThats funny right there !
  9. Mr48chev
    Had to read that one twice to get it :D
    36Tudordeluxe (that took three trys to get right) one simple way to figure how far your speedometer is off is to take a hand held gps and drive down the road with the gps set on the speed setting. If you don't have one a friend or relative most likely has one you can use.
    That way you can read your exact speed on the GPS and compare it to the speed reading on the speedometer and figure the percentage of difference and then find the gears that will correct that difference. No bs, no guessing on how many mph a tooth is worth in change.
  10. 36tudordeluxe
    36tudordeluxe
    Thank you, appreciate the math lesson, now I understand.
  11. e1956v
    e1956v
    Alliance Vendor
    Glad to help.
