How many threads should be showing on a lugnut?
Discussion in 'The Hokey Ass Message Board' started by evintho, Jul 31, 2013.
  1. BLUMEANIE
    BLUMEANIE
    from St. Louis
    ^ I was gonna say the same thing, ago. Most newer cars only take 72-75 ft lbs.
  2. hoop98
    hoop98
    from Texas
    You need the same depth of minimum thread engagement as the thread diameter. 7/16 studs need 7/16 engagement, 1/2 studs 1/2 etc to be NHRA legal.
  3. 55chieftain
    55chieftain
    Really not much differant than a mag wheel with no hub centric that people have run for years as long as the adapter is a good quality piece. A good torque wrench is your best friend to get them tightened evenly and routinely checked .
  4. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    You should really get a billet adapter instead of those old cast ones
  5. You mean the kind with shanked lugs ?
  6. 55chieftain
    55chieftain
    Yes, but similar in the way the studs center and support the wheel without a center register. I just pickep up a set of the plastic center adapters from jegs for a set ot steel slots I have for this very reason.
  7. M224SPEED
    M224SPEED
    from Missouri
    The rule of thumb has always been what Hoop98 posted. I have used it as a standard for 45 + years ,and it has never failed.
  8. 1971BB427
    1971BB427
    from Oregon
    There are thousands of mag wheels and custom wheels that don't fit snug on a center hub, even without an adapter. What's the difference with a wheel that doesn't fit the center hub without an adapter, and one that does?
    There are also thousands of unilug wheels that use washers inset in recess, and people said those were scary for years, but they've proven over time to work fine.
    As long as the lugnuts are properly torq'd and checked occasionally, I doubt it will ever become an issue. I'm not a fan of cast adapters, and I'd rather see billet or none, but they do work if properly installed and torq'd.
  9. I'm with Mike Miller, Machineryys Handbook and major bolt manufacturers say 3 threads visible for maximum strength. The last 2 threads are of an incomplete profile.
  10. As far as the center hole not touching the hub, my 56 MGA came from the factory with an 1/8" clearance all around. This style adapter has been on the market for ever, how many failures have they caused? (no other contributing cir***stances) Run them if you need to!
  11. I hear you, perfectly.
    but you or anybody else can have my share of them
  12. hallrods
    hallrods
    Aircraft Industry says 3 threads that flies for me
  13. Clik
    Clik
    Last few threads are tapered and don't bite. I was in a car once that was radically loud and had traction bars that were close to the ground. The driver yelled "Hey there goes some guy's wheel!" not realizing that it was his own bouncing past us. We were sliding along on the left traction bar as we crossed the Cabin John bridge.
  14. Ok loking at my machinists handbook here, and recalling my structural design courses and believe it or not they both say the same thing 1.5 threads past the end of the bol when properly torqued.
    Now here is something to consider, you have created several shear points by using a spacer. I would not be too concerned about it if it were my car but good design practice says this is not your optimum situation.
  15. gimpyshotrods
    gimpyshotrods
    I have run billet spacers (just like adapters, but same pattern) of up to 3", over 200, with no issues.
    I would not run a cast adapter, on a wheelbarrow.
  16. AZbent
    AZbent
    In the aviation world one full thread is good. But that is with self locking fasteners. I think 3 full threads and the lug nuts torqued to spec would be fine.
    Mark
  17. JEM
    JEM
    I'm obsessive about hub centering, not for strength but to minimize runout/vibration.
    I agree regarding cast adapters.
  18. jkherd
    jkherd
    :( Lose the adapters before you lose a wheel.
  19. Not just more shear points but also further out on the studs.
  20. Whatever combination of spacer or lug centric nuts you use, be sure to check the torque often on that new paint, it WILL compress
  21. ago
    ago
    from pgh. pa.
    Its a good idea to check the torque after mounting new wheels for the same reason, seating in.
    Ago
  22. Gotgas
    Gotgas
    from DFW USA
    ^^^These three comments are gospel.
  23. lakeroadster
    lakeroadster
    from *
    :confused: past the end of the nut...
    Silly and excessive.. but it's their sandbox, want to play? Follow their rules.
