Technical How much alternator vibration is OK
Discussion in 'The Hokey Ass Message Board' started by wearymicrobe, Sep 12, 2015.
  1. wearymicrobe
    wearymicrobe
    from San Diego
    So yeah the ***le. Converted the 57 Cadillac over to a three wire today because the generator kicked the bucket and replacements were $$$ instead of $. It's a standard GM unit.
    Yes I did the usual check the belt levelness and it is perfectly fine. So at idle its vibrating back and forth a good 1/4 inch in total stroke, more it up the RPM range and it settles out just fine. Is this going to kill the thing in 100 miles or 10K miles, not much more I can do to strengthen the mount.
    Seems to be spreading first the TBird killed its unit, then this and the truck has been acting up as well on hot start.
  2. 57JoeFoMoPar
    57JoeFoMoPar
    I don't know if it will kill it, but I'd certainly be concerned about that much movement. It should be held more rigidly than that.
  3. With that much movement I'd expect internal broken wires in a few hundred miles. I think you are taunting the octopus leaving it like that. LOL
    57JoeFoMoPar likes this.
  4. mgtstumpy
    mgtstumpy
    Is the bracket solid enough, without seeing a photo it's a guessing game. Alternator should be solid when mounted to an engine with only the belt moving. Whatever is causing your problem will become apparent when it fails.
  5. Ebbsspeed
    Ebbsspeed
    If it moves that much something will fail, just don't know if it will be the alternator or the mounts that fail first. Post up a couple of pictures of the mounts.
  6. wearymicrobe
    wearymicrobe
    from San Diego
    It's solidly mounted on the bottom I ground out the factory generator mount so that I could use the lower mount and then I had to heat up and bend a bit of the upper mount. Will take a photo tonight to show
  7. BJR
    BJR
    If everything is running true and the belt is in good shape, it should not vibrate like that. Something else is wrong with the setup.
  8. Texas Webb
    Texas Webb
    Maybe your heat&bend on the mount is allowing that movement.
  9. Maybe you are using the wrong belt that does not match the Alternator pulley groove.
  10. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    To be honest and not full of sh%t........NONE.
    gimpyshotrods likes this.
  11. Tell the truth, you're using an old belt, aren't you?? Buy a new one, it's cheaper than buying an alternator AND mounts after the vibes kill both.
    Cosmo
  12. rfraze
    rfraze
    Make sure and tighten the pivot bolts that go thru mount after getting the belt and adjuster tightened. Otherwise, the movement will break adjuster arm. Any movement after these bolts are tight, will require strengthening mount.
  13. Dan Timberlake
    Dan Timberlake
  14. Dick Stevens
    Dick Stevens
    Simple answer is virtually zero! :eek:
  15. Yep, any and it will fail...
  16. unkledaddy
    unkledaddy
    The whole alternator is vibrating or just the pulley?
    New or used GM unit.................. bearings burned up?
  17. X-2
  18. gimpyshotrods
    gimpyshotrods
  19. DdoubleD
    DdoubleD
    from Michigan
    X4 if you can see it "bending" it'll break. You may need just a simple brace to fix it. Think triangles.
  20. gimpyshotrods
    gimpyshotrods
