Technical How much can they take?
Discussion in 'The Hokey Ass Message Board' started by Grandpa's truck, Oct 22, 2018.
  1. Grandpa's truck
    Grandpa's truck
    So what is the safe amount of power you can put to a stock 40 chevy drive train?
  2. Chili Phil
    Chili Phil
    I could break stuff with the 216 six. Give you a clue?
    tractorguy likes this.
  3. Jethro
    Jethro
    As much power that it takes to break, it then back off a bit.
    XXL__, Deuces and Texas Webb like this.
  4. Consult your factory issued owners manual.
    I'd imagine the engineers that designed the vehicle knew what was appropriate, i.e. "safe".
  5. 6inarow
    6inarow
    trans is the weak link
    Chili Phil likes this.
  6. swade41
    swade41
    from Buffalo,NY
    You ever break a stick over your knee....bout that much
    slowmotion, Deuces and Texas Webb like this.
  7. 302GMC
    302GMC
    from Idaho
    You can destroy something in 1 block with a stocker …
  8. Terrible80
    Terrible80
    Deuces likes this.
  9. You can beat on the stock drivetrain like a government mule. Slow and steady but they will take a lot
    Trying to burn the tires and fly down the hwy .... not so much
    Read the top post about a stick over your knee if this is what your thinking
  10. TagMan
    TagMan
    I put a '62 235 (150 hp ?) in my '37 about 20-years ago. It originally had an 85 hp engine in it and I drive the snot out of it.
    Deuces likes this.
  11. Road Runner
    Road Runner
    I have a 261 bored .060 with RV cam and 3:55 rear gear and original transmission and torque-tube in my daily driver 48 coupe with drum brakes and pertronics ignition.
    Got 60K freeway and city miles on it thus far with no sweat or tears.
    Same setup but with a 235 in my 52 truck for over 100K miles and hauled full loads many times.
    Going strong for 23 years and never owned or needed another ride.
  12. I believe OP question was about '40 Chevy stock drive train, of which I admittedly don't have any personal experience with, hence my earlier suggestion.
  13. TagMan
    TagMan
    "I believe OP question was about '40 Chevy stock drive train, of which I admittedly don't have any personal experience with, hence my earlier suggestion."
    1937 & 1940 Chevy drive trains are not much different from each other.
  14. proartguy
    proartguy
    from Sparks, NV
    The ‘37-39 trans is similar. The ‘40 trans has an improved synchro ***embly which is a much better trans. The later trans also has bearings instead of shaft bushings. I went thru a bunch of the ‘37 versions due to blown synchros.
  15. slowmotion
    slowmotion
    Probably last indefinitely, until you start beatin' on it. Smooth & easy= long time, hammer down= aww ****...:eek::D
  16. Not much at all.
    If you do any performance to the engine the transmission is going to be an issue.
  17. bobss396
    bobss396
    Go easy on the hole shots...
  18. Gray Ford
    Gray Ford
    from Illinois
    Go easy on the half shots too....
    bobss396 likes this.
  19. jimmy six
    jimmy six
    BBC or KB ...... driven very carefully.
